Home -> Forums -> Construction -> Start Construction -> mohit
mohit
Wed Feb 05, 2014Total posts : 1
mohit
mohit
Topic: mohit
sir i need a help for planning a complex with basement and 2 store yard
i want to open retail shop on 1 floor like easy day .
whats around over all cost be in buliding ?area 5000
Wed Feb 05, 2014Post  #1
DearMohit
Start Construction-Construction Questions (20)
2451
3274
3285
4429
3975
2198
2699
4212
5169
2378
2294
1996
2447
2114
3195
2047
12514
2164
2012
2727
