Fri Sep 09, 2016Total posts : 1
Sandeep
Sandeep
Topic: Is mortar prepared using a mortar mixer of better quality than manual mixing?
Sun Sep 11, 2016Post  #1
Post subject: Mortar /concrete mixer
Dear Sandeep, Hello.! The Concrete /mortar mixer gives a better Mix than manual mixing , but be careful that the rotation speed and time of mixing should be within prescribed limit..otherwise it will result in sagaration (loss of binding ) .For smaller work its okay to use manual mixing but for major work the concrete mixer should be used with plate/pin Vibrator to get better quality . ..Regards
5943
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by S L Gupta (Civil Engg). Forum started by sunny420
2553
Mortar Plastering
Last answer on 10/11/2011 6:37:02 AM. by S L Gupta (Civil Engg). Forum started by sunny420
3589
Per Sq:ft rate for flooring
2840
Water seepage from RCC slab
3206
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
1958
3591
3564
Polimer fibres in mortar
Last answer on 8/23/2010 4:06:36 AM. by Girish. Forum started by Shridharan
1483
ABOUT ROD AND MORTAR USED IN THE ROOFING OF THE HOUSE
Last answer on 10/12/2015 10:20:41 AM. by S L Gupta (Civil Engg). Forum started by sumit
Shuttering Plywood
Last answer on 12/4/2011 6:16:40 PM. Forum started by Girish
1578
How to Apply Tile flooring in a room
Last answer on 3/24/2014 2:15:29 AM. Forum started by Purvi Panchal
2270
Interiors
Last answer on 8/17/2015 8:40:32 AM. by JAI PRAKASH. Forum started by manjula
6694
2371
i am civil engineerimg student iam in my last yeari am preparing my final year p
Last answer on 10/12/2021 10:36:28 PM. by S L Gupta (Civil Engg). Forum started by sultan
2238
Good and latest Bath Room Wall Mixer
Last answer on 6/10/2013 6:00:38 PM. by elinahenry. Forum started by raghuam
1969
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
2216
2351
Concrete Mix Ratio
Ready
Ready Mix Concrete
Hard
