Marble Flooring
How much Marole required
Sun Jan 15, 2017
Yousuf
Topic: How much Marole required
How much marble required for 120 sqr yards flooring of ground floor and ground+1.
Mon Jan 16, 2017
Dear Yushaf,
Take 10 % wastage in marble flooring. Take 10 % extra quantity from the actual area of flooring
Marble Flooring-Construction Questions (33)
1940
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
2212
Last answer on 12/14/2010 7:35:48 PM. Forum started by
Rakshit
2322
Last answer on 4/13/2011 6:59:26 AM. by
rammohandas
2059
how much green paint required in 1sqm
Last answer on 7/8/2011 8:24:30 AM. by
Abrar Ullah
sherab tenzin
3166
Last answer on 12/31/2020 2:11:59 AM. by
Ashok Negi
VILAYATWALA ALIASGAR ABBASI
2550
Tips for Varnish
Last answer on 3/17/2010 12:38:44 AM. by
vinay meghani
2811
Last answer on 12/31/2020 2:51:38 AM. by
SHAILESH
2448
Last answer on 8/6/2011 2:32:51 PM. by
nita
3043
Last answer on 8/18/2011 6:51:51 PM. by
prasadtvp
chella earnest
2004
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by
Krishna Equytech
2018
COST DETAIL REQUIRED
Last answer on 12/24/2013 11:43:24 AM. by
ANNA.B
2276
swarup chakraborty
2400
ineed plan and elevation and 3ddrawings.how much required
Last answer on 4/4/2014 2:07:38 PM. by
subramanian
2049
PVC windows
Last answer on 7/17/2014 6:16:20 PM. Forum started by
Raghu
2422
WE REQUIRE TILES DESIGN
Last answer on 7/8/2020 12:24:20 AM. by
JAGDEO PANDIT
1652
Last answer on 7/3/2015 3:57:17 AM. by
sandeep yadav
8820
Last answer on 7/3/2020 10:16:59 PM. by
sandeep yadav
1876
Last answer on 11/3/2016 10:40:18 AM. by
shashi
2046
required a plan for 28*60 south face plot with double bedroom
Last answer on 1/25/2016 11:52:22 AM. by
yugal
2422
JAGDEO PANDIT
2305
White Marble
Last answer on 7/7/2020 3:59:06 AM. by
Mohammad Abdul Ahad
Sri
2338
I want to make a almirah made of Granite. I will use this almirah for storage of
Last answer on 7/4/2020 2:28:45 AM. by
bhuvaneshwaran bn
AVINASH KUMAR
2281
which marble and its sub category to buy
Last answer on 7/3/2020 11:36:27 PM. by
sushantsah
1476
Marble Flooring
Last answer on 7/3/2020 11:14:17 PM. by
K. Basu
1898
Italian marble laying procedure
Last answer on 12/17/2015 2:56:51 PM. by
veby
2207
I have purchased katni marble. There seem to be cracks which run for about 3 fe
Last answer on 7/3/2015 3:42:03 AM. by
sivaprasad
248
flooring
Last answer on 2/27/2015 11:08:56 PM. by
sanu kumar
MUTHU
1797
italian marble flooring durable
Last answer on 7/11/2014 9:58:29 PM. by
sukhbir singh chadha
13318
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by
Sunny Bansal
Sunny Bansal
1717
Italian Marble Flooring
Last answer on 1/24/2014 3:40:11 PM. by
Nitesh Sainani
2523
i want to the price for marbel in sqft
Last answer on 12/18/2012 11:08:41 AM. by
V.M.BALAJI
2505
Flooring
Last answer on 12/17/2012 5:38:39 PM. by
Lokesh Saini
Anuj Anand
3395
Flooring
Last answer on 8/4/2010 6:26:18 AM. by
pumping iron
speyyeti
