Home -> Forums -> Construction -> Start Construction -> How much is the construction cost around Pune
Wed May 01, 2013Total posts : 1
Mahesh
Mahesh
Topic: How much is the construction cost around Pune
Hello Sir,
I am planning to build my own house 1K Sq.feet, ( 500 S.f. on Ground and 500 S.f on 1st floor), This plan sanctioned and developer had quoted 1400 rate for this construction. i. e. 14 Lacks Please advise on the rate and negotiation tips...
thank you!
Thu May 02, 2013Post  #1
Dear Mahesh
         The cost of construction at rs 1400-00 per sft is on higher side. Contractor does not agree on verbal tips. If you want bargaining with contractor, than take detail estimate. In detail estimate there are all the quantity of material, labor and rates then you will be able to negotiate in better way. A small expenditure give clear picture about your home project.See the link below
6035
Last answer on 10/18/2014 4:08:18 AM. by JAI PRAKASH. Forum started by bhatu
23866
2270
i need to construct a 200 sq feet house on the 3 rd floor in pune what will be t
Last answer on 10/18/2016 5:14:48 PM. by Amit Hasija. Forum started by sandeepkelkar
2035
What is the construction rate of commercial project in Pune right now.
Last answer on 1/25/2017 12:49:44 PM. by S L Gupta (Civil Engg). Forum started by Ritesh Bodake
6099
What is construction cost
2105
Construction Cost for Affordable Housing Project
Last answer on 7/7/2015 1:56:44 AM. by JAI PRAKASH. Forum started by Dipen Kadam
4647
Need Construction cost of G+1 house in Sanghvi, Pune
Last answer on 6/21/2016 9:15:47 AM. Forum started by rakesh
2172
55
Top Islamic Astrologers in Pune 91-7681982445
Last answer on 7/5/2024 1:45:18 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 1:45:19 AM. Forum started by Miyan Akram JI
53
Last answer on 7/5/2024 1:45:20 AM. Forum started by Miyan Akram JI
62
54
Last answer on 7/5/2024 1:45:21 AM. Forum started by Miyan Akram JI
55
Last answer on 7/5/2024 1:45:22 AM. Forum started by Miyan Akram JI
56
Last answer on 7/5/2024 1:45:23 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 1:45:24 AM. Forum started by Miyan Akram JI
3296
3309
2133
2059
