Home -> Forums -> Interior -> Study room Furniture -> how much is the cost of wood work persquare feet if inside is alaminate and outside is veeneer (costing 100 rs per sq. ft)
Wed Apr 06, 2011Total posts : 2
aslam
aslam
Topic: how much is the cost of wood work persquare feet if inside is alaminate and outside is veeneer (costing 100 rs per sq. ft)
pls giv me rough idea.
 diffnt people give  a wide range of cost. one carpenter is providing  kitply work with veneer in 600 rs/sqft. which acc to other person is duplicate work. how to know which carpenter to trust to/
Fri Apr 08, 2011Post  #1
Srinviasa
Srinviasa
Post subject: depends on materials used
Hi
It could range you anywhere from 350-650 Rs/ Sq Foot. Depending on quality of wood
waterproof or not branded or not what brand type of veneer worker (polishing) usually charges for polishing can vary from 50-80 Rs/ SQ Foot depending on quality of work
So best you can do is try to separate out the material costs and labour cost to decide on whether you are getting a goo quote or not
Mon Apr 25, 2011Post  #2
alagu chendur murugan
a commerical ply would cost you appx.Rs 55 in bangalore, a quality laminate around 65 and an arctificial veneer between 60 to 80 (natural veneer would cost you little more but the finish will be really nice) and the polishing for veneer is the same as veneer cost.
so anything between Rs 600 to 900 is good.
Murugan, architect
Study room Furniture-Interior Questions (21)
3925
23866
2245
2746
191901
2521
construction const
3225
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by Jemimmarichardson. Forum started by aammiitt
1777
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
2175
2733
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
16809
Construction Cost per square ft in Gurgaon
Last answer on 2/22/2013 11:53:26 AM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
2149
ESTIMATED COST FOR NEW BUILDING CONSTRUCTION IN RURAL AREA.
Last answer on 10/15/2015 2:19:56 AM. by JAI PRAKASH. Forum started by chitta naik
2342
I WANT TO KNOW THE ROUGH ESTIMATED COST FOR NEW 1450 SQ.FT. BUILDING CONSTRUCTI
Last answer on 10/15/2015 2:18:10 AM. by JAI PRAKASH. Forum started by chitta naik
1780
3196
labour cost
2978
starting new cnstruction
Last answer on 11/18/2011 4:58:34 AM. by Uday Kulhalli. Forum started by Uday Kulhalli
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
5664
What is the cost of the emulsion paint per sq ft as per today's market rate?
Last answer on 2/14/2013 11:17:01 AM. by Jemimmarichardson. Forum started by Rani
Always mention room size for which it is suitable. give diamensions of unit
Last answer on 7/3/2020 10:32:50 PM. Forum started by deepek
1827
do u hv stockists in kochi, kerala and cud pls inform the price of the furn abo
Last answer on 3/1/2011 4:27:50 PM. Forum started by lincy
What is acre
Designing
Designing a Foundation
CONCRETE
Garden
Garden Furniture
Garden furniture makes your garden relaxing place to sit. You can choose from a wide range of furniture like benches, ..
Cedar Wood
Purchasing Guidelines for Timber
Timber should be of first grade and be free from decay, fungal growth, boxed heart, pitch pocket or streaks on the split
Wood
Wood Roof Shingles
Hard
