How much steel and cementand concrete cement will be required to construct a cei
Mon Sep 12, 2011Total posts : 1
Raja Bunch
Raja Bunch
Topic: How much steel and cementand concrete cement will be required to construct a cei
How much steel and cementand concrete cement will be required to construct a ceiling of 450 sqft? Six columns has been erected and side walls done
Mon Sep 19, 2011Post  #1
Dear raja
      The quantity of cement and steel depends on the design of steel, number of beams and thickness of RCC slab and ratio of cement concrete.
2276
1766
1460
2684
steel requirment
1785
2866
Steel calculation
12998
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by S L Gupta (Civil Engg). Forum started by sanjay
3108
721
1876
Last answer on 11/3/2016 10:40:18 AM. by S L Gupta (Civil Engg). Forum started by shashi
1640
Construction Cost for RCC Roof / SlabsI am constructing a house 25* 36. slab thi
Last answer on 11/6/2015 12:49:45 AM. by JAI PRAKASH. Forum started by sandeep
2255
Sreel pillars(post)
2467
Retaining wall - Usage of Cement Plasticisers
Last answer on 7/23/2012 11:16:03 AM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
18435
3608
2902
construction cost
Last answer on 4/25/2018 1:08:42 AM. by S L Gupta (Civil Engg). Forum started by Sunil Kumar Singh
3589
Per Sq:ft rate for flooring
3470
Cost of concrete walls
Type
TMT
Concrete Decor
