Home -> Forums -> Construction -> Pillar Work -> How much weight can the pillars take?
Wed Jan 19, 2011Total posts : 2
rajkumarbn
rajkumarbn
Topic: How much weight can the pillars take?
I already have a 3 year old house with basement + 3 floors. Structure was designed with a structural engineer consultation. There are 12 pillars in the 30X40 area. Each pillar is 18 X 9 inches. each pillar has mix of 16mm & 12mm rods.
I am covering the terrace with roof tiles supported by steel structure (kind of addtional floor without walls). I have steel pipes with base plate planted to the pillars and roof tiles placed on this structure. this additional structure will add around 15 tonnes - 4 tonne steel (column, rafters, perlines) & 10 tonnes of double layer tiles.
My question is, will the current structure with the above specified pillars take this additional 15 tonnes without any problem?
Thanks,
Raj
Thu Jan 27, 2011Post  #1
Dear Raj
         According to details given by you, the structure i.e. pillars can take the load of new structure which you want to built now.
Fri Jan 28, 2011Post  #2
rajkumarbn
rajkumarbn
Thank you very much.
Pillar Work-Construction Questions (39)
2285
HI WHAT IS THE WEIGHT OF 1MX1M BARBEDWIRE FOR @10GAUGE
Last answer on 12/31/2020 2:08:42 AM. by H S Rathi. Forum started by K.SRINIVASAN
2646
Which is better for losing weight: peanuts or mahana?
Last answer on 9/24/2021 1:34:49 PM. Forum started by Celly Swehykol
664
What do you think about the effectiveness of diets for rapid weight loss?
Last answer on 6/14/2021 9:43:38 AM. by Salammm. Forum started by Salammm
3610
4238
Digging of Borewell and precautions to be taken.
Last answer on 3/9/2015 11:43:42 AM. by Pavan. Forum started by PCR.Manohar
1937
hullo anyone that can help me out with taking off software links thanks
Last answer on 5/22/2014 6:46:37 PM. by kintu henry. Forum started by kintu henry
1436
when do i deal with allowances when taking offthanks
Last answer on 5/21/2014 11:45:56 AM. by S L Gupta (Civil Engg). Forum started by kintu henry
1589
what precautions have to be taken for construction on South-West corner plot (46
Last answer on 9/15/2021 2:53:51 AM. by RadyGoldy. Forum started by prashant
50
Solve your love Dispute by taking Husband wife Problem 91-7681982445
Last answer on 7/5/2024 3:22:27 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 3:22:29 AM. Forum started by Miyan Akram JI
55
Last answer on 7/5/2024 3:22:31 AM. Forum started by Miyan Akram JI
59
Last answer on 7/5/2024 3:22:32 AM. Forum started by Miyan Akram JI
58
Last answer on 7/5/2024 3:22:33 AM. Forum started by Miyan Akram JI
60
Last answer on 7/5/2024 3:22:34 AM. Forum started by Miyan Akram JI
57
Last answer on 7/5/2024 3:22:35 AM. Forum started by Miyan Akram JI
61
Last answer on 7/5/2024 3:22:36 AM. Forum started by Miyan Akram JI
59
60
Last answer on 7/5/2024 3:22:39 AM. Forum started by Miyan Akram JI
60
Last answer on 7/5/2024 3:22:40 AM. Forum started by Miyan Akram JI
32561
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
4037
42125
12462
First floor construction
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9229
pillar size in distacce
9196
2823
2695
1994
2208
3161
Laping length requirement
Brick Pillar
Density of Coarse Aggregate
What preliminary steps should be taken before terrazzo tile flooring?
If any tile is not in perfect square shape, it will spoil the entire flooring.
Make your room magical and fascinating with curtains
Stylish and inviting curtains for your homes: Spruce up your interiors with the enchanting shades of extensive curtain..
