Home -> Forums -> Vastu -> Drawing Room -> my house entrance is NE.and there is astore room at entrance and a guest toilet
Thu Mar 10, 2011Total posts : 2
VIOLET PANDIAN
VIOLET PANDIAN
Topic: my house entrance is NE.and there is astore room at entrance and a guest toilet
my house entrance is NE.and there is astore room at entrance and a guest toilet when you enter the house they r at each side inside the entrance door and its a flat. can u suggest vastu for this flat is a company house. Do suggest me onthis
Fri Mar 11, 2011Post  #1
Post subject: NE toilet Store room
Dear Violet,
The store room should be used as a study room/library or a place for worship. The guest toilet should not be used on a daily basis. Try to light a yellow 0 watt bulb for 24 hrs in the toilet..
Sabina Vanjani
Vastu Analyst
Sat Mar 12, 2011Post  #2
Dinesh Manaktala
Dinesh Manaktala
Post subject: Toilet and Store room in N/E.
Well Violet,
There should not be any of those in this direction. Better if clean the store and use it as a pooja room or a study. At least do not keep heavy materials in this room. This room might be lighter and clean then any other room of the flat.
For toilet in this direction, First u ensure to use this toilet on least basis. Avoid using this as it should not be possible for to to fill it up and close in a company provided flat. Enlighten this place with light green for maximum time and place some non purified see salt kept in a crystal/glass small bowl in the ventilator of this toilet. change the salt after every month or as u see its turned a little grayish.
Best of Luck.
Dinesh Manaktala.
Architectural and Interior Designer and Vastu Consultant, Saharanpur.
1919
i am talking about an entrance or a distributor for the kitchen and the living r
Last answer on 9/29/2012 3:25:08 PM. Forum started by adel
1780
1983
One guest room,two attached bedroom,kitchen,toilet,puja room
Last answer on 10/21/2015 11:53:56 AM. by S L Gupta (Civil Engg). Forum started by anup Kumar
3521
My house is south facing,SW entrance,SE drawing room,South kitchen then NE pooja
Last answer on 8/5/2011 7:14:57 PM. by sabina vanjani. Forum started by Sankalp Ahluwalia
3697
about size of chowkets
3741
Pooja Room Vastu
Last answer on 10/3/2015 11:17:32 AM. by S L Gupta (Civil Engg). Forum started by sam
2448
interior 4 living room entrance (door) 4m east size 12ft*14ft
Last answer on 10/19/2021 2:25:10 AM. Forum started by nisar
2922
a drawing room on sump
Last answer on 4/19/2011 12:39:43 PM. by kamalesh. Forum started by raj
1521
I want a house plan of size 56 x 60 . South Facing plot.
Last answer on 9/9/2016 11:23:23 PM. by bhuvaneshwaran bn. Forum started by Sumeet
3287
my house entrance is from south direction and my bed room is in north east. pls
Last answer on 11/26/2012 1:28:04 PM. by sonigupta. Forum started by ritu jain
13253
what is the remedy if we have toilet and bathroom in north east direction? can w
Last answer on 4/21/2011 2:13:31 AM. by Nitien Parmar. Forum started by kamal
3884
is it okay to have a toilet just next to the main gate/ entrance in the west dir
Last answer on 12/10/2009 12:07:55 AM. by juhi. Forum started by poonam_gunjiyal
1613
can any body tell me how to design econimacilly the entrance side of the house
Last answer on 8/31/2011 7:38:33 AM. Forum started by rama ramana padhy
2072
main entrance for house
Last answer on 5/19/2015 9:07:52 PM. by JAI PRAKASH. Forum started by charit
1252
1585
The entrance door of my house is at north,means when it opens it faces south and
Last answer on 10/3/2016 2:00:39 PM. by S L Gupta (Civil Engg). Forum started by nitu v.
2487
new house
Last answer on 8/1/2018 11:41:51 PM. by S L Gupta (Civil Engg). Forum started by kalyan
2452
I have constructed house facing south as per my star and unavoidably kitchen at
Last answer on 9/30/2009 12:07:33 PM. by Priti Arora. Forum started by Vijay
1777
I AM GOING TO BUY A PLOT OF EASTFACEING (ITS MAIN ENTRANCE MAY BE POSSIBLE WHEN
Last answer on 12/31/2010 4:30:42 PM. by S L Gupta (Civil Engg). Forum started by bgsolanki
3676
3086
2316
2345
3406
2265
5121
1845
7104
2554
2143
1723
1821
1833
2073
5822
2676
7306
7537
2704
Which are various sources of entrance for termites in a building?
The timber buried in ground. The means of mud shelter tubes constructed over unprotected foundations
Utilization
Painting
Environmentally
