Home -> Forums -> Construction -> External Stairs -> my question is - i have a house with ground floor.1000sft . brick construction i
Sat Jul 20, 2013Total posts : 1
atanu modak
atanu modak
Topic: my question is - i have a house with ground floor.1000sft . brick construction i
my question is - i have a house with ground floor.1000sft . brick construction i.e.no piller.now i want to build 1st floor. what will be the approx cost?my 2nd q. is my ground fl.roof is damaged.water sips th. it in some places during rainy season.how shall I permanently repair it before construction of 1st floor ? please help me.
Tue Jul 23, 2013Post  #1
Dear Modak
  The cost of construction is based on the plan  and specification used in the construction of building.  cost is also co related with types of foundation,earth quack measure. For accurate costing you can e-mail at support@gharexpert.com for detail estimate.See the link below.
For repair of leakage take help from local civil engineer,
External Stairs-Construction Questions (29)
3015
Rate of construction of 1st floor of private house 1000sft. in kolkata
Last answer on 2/2/2016 6:19:47 PM. by S L Gupta (Civil Engg). Forum started by A Ghosh
3230
2865
Bricks
1340
1871
12572
duplex house plan
Last answer on 7/4/2020 2:04:56 AM. by bindu. Forum started by sasikumar
2539
Last answer on 7/4/2020 2:31:17 AM. by S L Gupta (Civil Engg). Forum started by ramaiyacp
2991
1669
Cement requirement
2474
1479
3992
5124
4107
COST construction of only 1 story house and construction of G+4 residential cost is 1:5 or different
Last answer on 12/8/2014 8:24:49 AM. Forum started by azad
2551
Advise on accommodating a staircase in existing structural plan
Last answer on 5/30/2021 11:00:09 PM. Forum started by Naveen Reddy
15360
2nd floor construction
2572
2820
Super Structure construction
Last answer on 9/25/2020 4:33:02 AM. by S L Gupta (Civil Engg). Forum started by aryan
8685
i have 15 ft width & 30 ft length plot which ihas to develop tell me the plan &
Last answer on 10/28/2021 12:01:35 AM. by S L Gupta (Civil Engg). Forum started by RANJIT SINGH
3222
Last answer on 7/12/2021 6:05:13 AM. Forum started by vgshekar1
7401
I have 1000 sq.ft.plot in thane and want to make house for personal use.Pls.let
Last answer on 7/4/2020 4:26:37 AM. by S L Gupta (Civil Engg). Forum started by ashish kangutkar
1374
I want external stair design
Last answer on 4/2/2016 11:25:11 AM. by S L Gupta (Civil Engg). Forum started by pushpak
1518
the way of comming out with such
Last answer on 7/3/2015 3:51:40 AM. by JAI PRAKASH. Forum started by tindimwebwa alfred
2240
Good design house. could you please layout plan/ no.of rooms etc. on my male ple
Last answer on 1/25/2014 6:58:59 PM. by Navneet Jharia. Forum started by k k upadhyay
2195
really Exciliant ledder
Last answer on 10/18/2011 9:24:31 PM. Forum started by sunil singh
2650
I M CONSTUCTING A HOUSE WIT 23 FEET FRONT IN EAST FACING N PLANNED A GATE IN
Last answer on 3/18/2011 10:25:22 PM. by Dinesh Manaktala. Forum started by RAJAN NARULA
3228
Would like to know is it correct to use the M.Sand instead of river sand for the
Last answer on 10/30/2010 2:10:01 PM. by S L Gupta (Civil Engg). Forum started by kcantony
3125
1. Thanx for a lovely design. 2. Please show the interior of each room too for
Last answer on 2/8/2010 10:09:09 PM. Forum started by baldev
Preliminary
Why
Brick Arches
