Mon Aug 30, 2010 | Total posts : 2 |
| Topic: my under ground water bore is in the north west direction, the house is west fac
my under ground water bore is in the north west direction, the house is west facing . kindly tell vastu remedy |
Mon Aug 30, 2010 | Post #1 | sabina vanjani
A borewell in the Northwest can affect the offsprings, prevent growth of family, creates enimity, mentalproblems and money loss. Since the gravity of problem is too much I would recommend that you try and move the bore to Northeast. Any remedy suggested shall not work in toto
Sabina Vanjani-Vastu Analyst
Wed Sep 01, 2010 | Post #2 | marie
Join date: Jun 2010 | Post subject: septic tank in the northwest too
I have a similar situation, except this house faces east. the house is finished hence can no longer move the septic tank which is underthe bathroom anyway. is there hope for this problem? | |
Questions (39) | |
2959 views | 2 answers | Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta | 2333 views | 2 answers | Last answer on 11/7/2021 11:26:13 PM. by Nitien Parmar. Forum started by Reena | 2119 views | 0 answers | Last answer on 9/13/2010 4:33:09 PM. Forum started by Asha Khaitan |
| 2694 views | 1 answers | Last answer on 8/24/2012 1:56:34 PM. by Amit Hasija. Forum started by mahender | 4480 views | 2 answers | Last answer on 3/5/2021 3:03:42 PM. by Prabha. Forum started by Prabha | 1638 views | 1 answers | Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna | 2442 views | 3 answers | Last answer on 5/3/2016 12:15:23 AM. by JAI PRAKASH. Forum started by Anuj | 1994 views | 1 answers | Last answer on 4/24/2012 2:40:32 PM. by Amit Hasija. Forum started by minal | 4273 views | 1 answers | Last answer on 8/12/2020 2:58:49 AM. by baba morris. Forum started by geetha | 1844 views | 1 answers | Last answer on 2/16/2017 2:10:10 PM. by S L Gupta (Civil Engg). Forum started by MRINAL SENGUPTA | 3230 views | 1 answers | Last answer on 1/5/2022 9:43:17 PM. by S L Gupta (Civil Engg). Forum started by v.r.kumaar | 2374 views | 2 answers | Last answer on 7/3/2020 11:00:43 PM. by S L Gupta (Civil Engg). Forum started by yasothabalanr | 14932 views | 1 answers | Last answer on 7/3/2020 10:46:04 PM. by Dinesh Manaktala. Forum started by SAndeep | 1583 views | 0 answers | Last answer on 6/25/2012 10:29:40 AM. Forum started by sanjaya kumar mahapatra | 5171 views | 20 answers | Last answer on 12/22/2009 4:23:49 PM. by Praveen. Forum started by amarchatterjee | 1267 views | 1 answers | Last answer on 11/25/2016 2:04:33 PM. by Beenu Phogat. Forum started by saravana prabu | 2261 views | 2 answers | Last answer on 9/6/2010 11:06:42 PM. by a vasanth kumar. Forum started by tanmay | 2726 views | 2 answers | Last answer on 5/31/2012 5:39:05 PM. by Sumsn Kumar Mohanty. Forum started by lakshmana Chari | 3053 views | 1 answers | Last answer on 12/17/2020 3:55:26 AM. by Pavan. Forum started by paresh | 13 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 10 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 8 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 13 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 11 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 23 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 27 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
Articles that might interest you! | | The 4 Cardinal Directions The directions are one of the most important factors in both Feng shui and Vaastu. The positioning of main entry door, v | | Specification of 'Bricks Walls' Strong brick walls are a symbol of strong building. Whole construction process somewhere depends on it. So here is a b.. | | Vastu for Water Tank It is important to place water bodies in Vastu friendly manner to preserve resources and energies. Under ground water .. | | Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. | | What is recommended method for opening in load bearing masonry walls? .Vertical clear distance between openings should be less than 60cms.
.Horizontal clear distance between openings shou.. | | Pool Pumps Pool pump is the most important equipment of your swimming pool. This device works with filter to maintain the cleanline | | Planning a House Once the architect has given his design options, it becomes necessary to select one and start working on it. | | Layout of Building The real meaning and purpose of setting out (layout) is to transfer the plan, length and width of its foundation on th.. | | Inviting prosperity through the Main Door The Main door being the most majestic & huge should always open inwards & the location of main door in a house or a pl.. | | Painting Exterior of your Home For painting exteriors of your home, you should know proper guidelines on primer, paint quality, paint color, weather .. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
