Home -> Forums -> Construction -> Layout and House Plans -> need help for new home plan
Tue Apr 17, 2012Total posts : 1
gaurav
gaurav
Topic: need help for new home plan
dear sir,
i m basically from delhi & i m having a land of 30 x 60 feet i.e 200 sq yard area of plot i want to construct it with stilt parking & 4 floors for residence please provide me the construction cost estimate & as i think in delhi 75% land can be covered so please provide me the architect drawing for particular....
Thanking You
Tue Apr 17, 2012Post  #1
Post subject: Browse Readymade plans from gharexpert.com
We have launched a very cost effective architectural plan service that provide you readymade floor plans:
Please use the links given below that matches your requirements:
  • You select a plan whose layout you like. Note down the plan code and purchase the plan.
  • Once you purchase the plan, we will contact you and send you a questionnaire through which we will understand your requirements.
  • We will assign a representative for your project and he/she will coordinate all your requirements.
  • After discussions with you, we will adjust the plan according to your exact plot size and make as many changes as you like. Our prices are based on per square feet of built area and if after changes your built area increases by more than 10% then we will change for the increased area accordingly.
  • If you also purchase guidance from Vastu expert then an independent vastu expert be assigned to your project and he/she will review your plan and suggest changes.
  • Once the plan is finalized, we will give you dimensions as shown in the sample drawing and door window schedule.
  • If you purchase more drawings then the same will be delivered to you according to the plan finalized by you.
  • If you choose a 3-D option too, then the process works as below.
    • After completion of the architectural plans, we will recommend and send to you a few pictures/3-D models of the homes. In those pictures, we will ask you to shortlist the items of the exterior elevations. You can also send us the pictures of homes that you like. Through the existing pictures, it will be easier for you to shortlist the material and shape of exterior elevation.
    • Based on the architectural plans and your preferences, our 3-D designers will design the 3-D elevation for your home.
  • If you purchase, 3-D elevation plan then you should also purchase the 2-D elevation plan as all dimensions and levels are provided in the 2-D elevation plans. Your contractor would use the details in the 2-D elevation plan to construct your home. The 3-D pictures are there for a reference so that both you and your contractor can visualize the same thing.
  • We have service for the construction cost estimate which would give you the brick by brick cost calculation
Our detailed cost estimate pricing is based on the built up area of the house and price slabs given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.25 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.75 per sq.ft.
Above 10000 sq.ft area= Rs.1.25 per sq.ft.
We will take almost 12 business days to prepare the detailed cost estimate.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
We have the prices for all the building materials/ contractors/ labor charges from all over India, So we would incorporate prices as per your city.
For preparing the detailed cost estimate, We need additional documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Do you have exterior elevation design and structural drawings provided by your architect?
7. Please supply floor plans.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
1896
hi, need all support to make new homes
Last answer on 5/27/2016 6:17:16 PM. by mukesh. Forum started by Dr Tushar Panigrahi
2383
I need 16*40 home sketch with vastu please help me
Last answer on 4/25/2013 10:39:22 AM. by Amit Hasija. Forum started by Sharath
hi im new home plan frent 36 light 25
Last answer on 7/3/2020 10:19:19 PM. by S L Gupta (Civil Engg). Forum started by sandeep
804
2254
we need the plot plan for this home,
Last answer on 7/5/2011 12:10:05 PM. by kawalnain kaur. Forum started by Devendra Kumar Pandey
1747
Please help appointing a full time contractor for constructing a new home.
Last answer on 12/1/2010 3:54:39 PM. by prasad. Forum started by Solomon
1823
i will meak a new model home help mi of front disine elevtion playining call; me
Last answer on 2/16/2013 1:15:17 PM. Forum started by janakiram
1181
2506
Wanted the Construction and 3D plan according to Basic plan we have.
Last answer on 9/10/2014 8:26:24 PM. by seema tyagi. Forum started by Sricha Gupta
2309
New Home
2324
2107
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
4039
1847
Hi,greetings, can any body help to prepare construction plan for my home to be s
Last answer on 6/26/2014 10:45:04 AM. by seema tyagi. Forum started by vasa
4832
Need a house layout plan for 450 sq feet land - size - 15ft X 30ft. pls help
Last answer on 5/13/2016 1:11:58 PM. by kushagra khare. Forum started by ankur gupta
2182
Last answer on 7/20/2015 7:12:25 PM. by JAI PRAKASH. Forum started by rishi
1442
Hi i need house plan for 35 *45 plot. Plz help
Last answer on 7/3/2020 10:57:01 PM. by S L Gupta (Civil Engg). Forum started by Samina
1105
Last answer on 1/29/2019 12:52:35 AM. by S L Gupta (Civil Engg). Forum started by Rajeevalochana
1590
need a house plan
Last answer on 7/6/2021 11:26:53 PM. by AR. HIMANSHU PHOGAT. Forum started by neha
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Happy
Happy New Year 2009
