Home -> Forums -> Construction -> Door Frames -> need little calcultaion
Sat Mar 08, 2014Total posts : 7
gaurav
gaurav
Topic: need little calcultaion
hello please help me i just want to know the calculation for measuring the price of door frame as i m getting 200 rupees price for running feet of 8 feet x 6 inch wide log & my door frame is of  7.6 height 3 feet width n 6 inch x 2.5 inch. so please tell me how to calculate price for door frame & how to convert price of running feet to sqaure feet of wood.
thank you
Sun Mar 09, 2014Post  #1
Post subject: Calculation of Quantity of Wood for door frame ...
Dear Gaurav, hello..!
 The Wood required for a  door frame 7'-6" x 3'-0" with section of 6" x 2.5"
  6" x 2.5" x 7'-6" long  x  2 no..= 1.5624 Cu.Ft.
  6" x 2.5" x 3'-0" long  x  1 no..=  0.312  Cu.Ft.
                                     Total   =  1.8744 Cu.Ft. if the cost of wood is Rs.!500 per Cuft
The total cost will be 1.8744cuft. x Rs.1500 = Rs. 2811.60
To convert cost in to Running foot---
   7'-6" long  x  2 no.=15  ft.
   3'-0" long  x  1 no = 3   ft.
                     Total.= 18 Running ft.   Total cost is divided by running foot you will get the cost of wood section 6" x 2.5" in running foot..ie. 2811.60/ 18 = Rs.156.20... I hope it will solve your problem...Regards
Sun Mar 09, 2014Post  #2
Let us find the quantity of wood in 1 frame.
7.5 feet x 2 = 15 feet ( running ft.)
3.5 feet x 1 = 3.5 feet ( running ft.)
total wood =  18.5 running ft
you say rate is 200 rs per running ft then the cost of frame
18.5 x 200 rs = 3700 rs.
Mon Mar 10, 2014Post  #3
gaurav
gaurav
thank u very much navneet sir n purvi mam....
Mon May 11, 2015Post  #4
agg
agg
Post subject: calculation
please explain how you got 3.5.
my door size is 8 feet by 3feet and 6 inches  by 3 inches.
I am totally confused.
thanks
Tue May 12, 2015Post  #5
For a door frame of 7*3, total would be 7+7+3 = 17 feets.
Wed May 13, 2015Post  #6
Naveen Reddy
Naveen Reddy
Good explanation! Thanks all of you. Even i was searching for something like this.
Calculation of wood for Door Frames part is clear Pretty clear now.Also wondering if you can  please explain, how to calculate wood for Doors? (for Single and double shutter).
Thanks in advance,
Naveen :)
Thu May 14, 2015Post  #7
Wiremesh Door - Same process
Complete wood Door - Square feet. e.g. 7*3=21 sq.ft.
Door Frames -Construction Questions (32)
2137
BUT I WANT A LITTLE SIMPLE DESIGN IN MAROONISH RED AND GOLDEN YELLOW WITH SPOT L
Last answer on 3/2/2012 5:07:23 PM. Forum started by DORIS
485
How can I relax a little and have a good time?
Last answer on 2/22/2022 6:41:35 AM. Forum started by John Staples
2284
great design,but a little bit compacted,more space,less wares,that is well arran
Last answer on 3/31/2010 6:29:15 PM. by Ajit Tareeka. Forum started by joel
1663
My slab plaster is spilling and reinforecement is little wrotten,i try to plaste
Last answer on 11/4/2010 7:43:55 PM. by balendu. Forum started by nith_piyush
6679
little detail required
Last answer on 10/22/2020 10:47:11 PM. by Navneet Jharia. Forum started by gaurav
3002
my new house construction is going on.my dining room is little bit raised from
Last answer on 8/24/2012 1:06:16 AM. by priya shah. Forum started by arti
2766
MADAM,I AM HAVING 200SQYD OF OPEN PLOT WHERE I WANT TO START A CONSTRUCTION FOR
Last answer on 4/12/2021 7:23:05 AM. by Swati Satija. Forum started by mrs sudha
1964
any body who can suggest a good plot say 1gd or little less in chennai mainly in
Last answer on 5/3/2016 11:37:46 PM. by JAI PRAKASH. Forum started by D.Ramachandran
1577
i need a map for 23827 feet (80 yards)
Last answer on 5/31/2016 12:05:56 PM. by Beenu Phogat. Forum started by hayat
1732
New building plan 150 Square Yards
Last answer on 12/8/2016 3:41:39 PM. by Beenu Phogat. Forum started by riyaz
1638
1832
Last answer on 9/8/2021 6:08:07 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja
2910
i need help for my master bedroom too.my masterbedroom walls had same color as t
Last answer on 12/31/2020 2:06:06 AM. by Gunjan Utraja. Forum started by rani
3149
Last answer on 5/6/2014 3:12:22 PM. by seema tyagi. Forum started by ranjana
1855
I NEED LAYOUT FOR SHOWROOM , OUR SHOP EAST FACING ,DUPLEX SHOWROOM ,I NEED STIRC
Last answer on 8/29/2010 4:20:41 PM. by sabina vanjani. Forum started by ANOOP JAIN
2624
i need vastu plan for south facing
Last answer on 8/27/2010 9:48:39 AM. by sabina vanjani. Forum started by jayanthi
3184
Last answer on 3/16/2017 11:32:26 AM. by S L Gupta (Civil Engg). Forum started by vijay jaswal
1949
I NEED LAYOUT FOR SOHP STIRCASE ,LOCKER ALMARAS ,OUR SHOE IS EAST FACING DUPLEX
Last answer on 8/29/2010 4:06:02 PM. Forum started by ANOOP JAIN
2012
need information how to import these doors
Last answer on 9/14/2010 12:56:45 AM. by martin. Forum started by martin
4735
3219
29140
wood calculation
Last answer on 1/5/2022 2:17:35 AM. by Navneet Jharia. Forum started by agg
2858
Column Size and distance
5017
1672
outside main gate
Last answer on 11/17/2020 12:09:44 PM. by S L Gupta (Civil Engg). Forum started by Pooja
2689
DOORS
10466
1734
1889
door frame height
Last answer on 12/29/2015 12:49:44 AM. by JAI PRAKASH. Forum started by Pooja
2075
2981
Door window frame
Last answer on 12/16/2013 9:13:21 AM. by . Forum started by Purvi Panchal
3479
Last answer on 3/4/2013 6:35:55 PM. by S L Gupta (Civil Engg). Forum started by P. Panchal
Why
Proper
