Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> need your guidance
need your guidance
Sun Apr 22, 2012Total posts : 1
ketan jayswal
ketan jayswal
Topic: need your guidance
dear Mr. Gupta
i have a tenament house which is only ground floor has 31x29 sq ft of construction and plot size is around +1400 sq ft and my next door neighbor build his house 3 stories years ago for which i shared cost for common wall , my question is that if i want to build 2 more stories on my ground floor house what should i consider when it comes to a foundational point of view  like
1) how many pillars (columns) should i consider before i start construction for 2nd and 3rd floors and what is your best advice for best material and diameter of pillars(columns) should be, how much should pillars(columns) cost ?
2)what is a best way to build 2 floors, please give me detail advice. and what will be the rough cost estimate to build around 2000-2400 sqft?
Note: also need separate answers (house originally RCC built)
please email reply to:    kjayswal@gmail.com
Mon Apr 23, 2012Post  #1
Dear Kaitan
        The position of pillars are maked after the study of plan of the building or house according to the requirement of loading condition the size of column is calculated. If you want than send to support@gharexpert.com.
The cost of the building is depend on the specifictions used at the time of construction.
2225
Hi.. I need your guidance
Last answer on 9/6/2010 9:37:09 PM. by Gunjan Utraja. Forum started by shrishail
2142
Need your guidance
Last answer on 8/20/2012 12:27:18 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
2021
bathroom toilet in the north
Last answer on 7/3/2020 10:12:12 PM. by ADINATH. Forum started by ADINATH
3166
1574
HI required guidance to build 22*51 plot size with road on both side.
Last answer on 3/16/2015 9:54:10 AM. by seema tyagi. Forum started by pradeep
1369
Need advice for constructing commercial building with a pent house
Last answer on 9/9/2016 11:42:58 PM. by bhuvaneshwaran bn. Forum started by Mini
12998
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by S L Gupta (Civil Engg). Forum started by sanjay
1646
Damaged Terrace Slab
Last answer on 6/7/2014 3:05:43 PM. by S L Gupta (Civil Engg). Forum started by chandran nedungadi
4162
help required by experts
Last answer on 12/25/2020 3:37:50 PM. by S L Gupta (Civil Engg). Forum started by gaurav
2141
Layout plan
Last answer on 12/26/2011 12:25:30 PM. by ravi at Dalmia. Forum started by Geetha Pattabiraman
1577
i need a map for 23827 feet (80 yards)
Last answer on 5/31/2016 12:05:56 PM. by Beenu Phogat. Forum started by hayat
1638
1832
Last answer on 9/8/2021 6:08:07 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja
2910
i need help for my master bedroom too.my masterbedroom walls had same color as t
Last answer on 12/31/2020 2:06:06 AM. by Gunjan Utraja. Forum started by rani
3149
Last answer on 5/6/2014 3:12:22 PM. by seema tyagi. Forum started by ranjana
1824
needs ur contact in city rawalpindi pakistan......my contact no is from pakistan
Last answer on 5/26/2014 10:51:50 AM. by S L Gupta (Civil Engg). Forum started by shahid
1994
How to select Mason
Last answer on 2/3/2022 11:34:26 PM. by JAI PRAKASH. Forum started by syedwajidali
2338
1807
5811
3792
9885
2670
4628
4143
2865
5007
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Why
Proper
