Home -> Forums -> Construction -> Start Construction -> new constuction help required
Thu May 03, 2012Total posts : 2
gaurav
gaurav
Topic: new constuction help required
hello all i m having plot of 200 sq yard in delhi
& as per m.c.d  rules in delhi 75% area can be covered & far is 300% plot size is 30 x 60
.i m looking to construct it with ground stilt parking & 4 floors for living. please let me know normal construction & other chargesin delhi it will be with 6 person lift.need advice from experts in architect & structural engg.
thank you
Thu May 03, 2012Post  #1
gaurav
gaurav
Post subject: sorry
forgot to mention the requirement is 3 bedrooms+2 toilets/bathroom attached 1 common toilet/bathroom+ 1 kitchen +1 guest room(drawing room) + puja room +lobby
Fri May 18, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Hi Gaurav,
The first step should be to get the architectural plan done. You can choose a plan from the link below or hire an architect for a plan.  The process should work as below.
1) You hire an architect firm to build a plan.
2) Based on the architect's plan, structure engineer would make structure drawings.
3) Structural drawings are done for earthquake safety and other measures. And on the basis of these drawing, your contractor would quote you to build the structure.
If you get a quote without drawings in hand or if the contractor is offering to make architectural plan then it would lead to dispute late on or the structure recommended by the contractor may not be the best for the area.
The link below has plans that you can purchase
2733
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
2447
2668
Estimate require for new construction
Last answer on 7/3/2020 10:05:34 PM. by JAI PRAKASH. Forum started by Pradeep Patil
2107
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
2863
2660
Last answer on 2/24/2022 11:54:36 AM. by S L Gupta (Civil Engg). Forum started by KUMAR RISHABH GIRIRAJ
4011
sir i am going to construct 30 to 40 house at my site. i am interested to discus
Last answer on 12/18/2021 1:23:23 AM. by Amit Hasija. Forum started by jiten adesara
2102
river sand
4264
860sqft construction
Last answer on 10/12/2015 6:35:12 PM. by Rahul. Forum started by Shivaprasad
1823
i will meak a new model home help mi of front disine elevtion playining call; me
Last answer on 2/16/2013 1:15:17 PM. Forum started by janakiram
3157
I m starting my new business of construction , kindly help me with some details
Last answer on 7/24/2021 4:15:31 AM. by Rinder76. Forum started by Tarun
1748
Please help appointing a full time contractor for constructing a new home.
Last answer on 12/1/2010 3:54:39 PM. by prasad. Forum started by Solomon
1181
3318
Last answer on 5/1/2012 11:09:41 AM. by S L Gupta (Civil Engg). Forum started by pankaj sharma
6065
Help required: House plan for 33 x 50 Sq ft North facing plot
Last answer on 7/2/2020 10:07:28 PM. by S L Gupta (Civil Engg). Forum started by sheeja
1956
Cracks in the slab - urgent help required
Last answer on 7/5/2013 4:03:51 PM. by vamsi. Forum started by vamsi
4162
help required by experts
Last answer on 12/25/2020 3:37:50 PM. by S L Gupta (Civil Engg). Forum started by gaurav
2611
Vastu for an apartment -- help required!!!
Last answer on 12/31/2020 2:19:12 AM. by anil. Forum started by C A N Naick
2213
Last answer on 12/14/2010 7:35:48 PM. Forum started by Rakshit
3312
2236
2312
2061
Happy
Happy New Year 2009
Bedroom Makeover
Happy
Happy New Year 2009 Wishes and Wallpapers from Gharexpert
GharExpert.com launched 2009 wallpapers.Check them out and let us know how they look.In order to setup these pictures..
Happy
Ceiling
