on mat iron pillar nos on eastern side -30 feet s are erected and concrete done.
Sun Jul 27, 2014Total posts : 1
bhushan.k.g.m.
bhushan.k.g.m.
Topic: on mat iron pillar nos on eastern side -30 feet s are erected and concrete done.
on mat iron pillar nos on eastern side -30 feet s are erected and concrete done. box not yet done. Neighbour wants one feet gap. Can I bend the iron rods by on foot and add concrete and box it ? bhushan.k.g.m.
Tue Jul 29, 2014Post  #1
Dear Bhushan
         You can bend the MS Steel bars in columns.
Sreel pillars(post)
2421
start construction Steel use
65238
18435
3608
1542
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
9225
pillar size in distacce
4587
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
9216
Standard weight of iron grill per feet
Last answer on 8/25/2014 8:17:34 PM. by JAI PRAKASH. Forum started by paresh
3278
3456
2151
house plan for 39 feet road side and 32 feet depth for noth facing
Last answer on 1/2/2015 11:13:55 AM. by seema tyagi. Forum started by ravi kiran
2535
Civil Eng Stair Design
2535
2537
RCC column (pillar)
2101
1004
Is it possible to fix compound wall iron gate weighing around 150kg on a 8"x8" r
Last answer on 7/4/2020 4:17:59 AM. by S L Gupta (Civil Engg). Forum started by vinu
1794
drawing room
Last answer on 2/15/2022 9:31:24 AM. by mamtagarg. Forum started by sudha
Brick Pillar
Bathroom Accessories Part-4
Designing
Designing a Foundation
Concrete Decor
Concrete Mix Ratio
Centering
Ready
Ready Mix Concrete
