which one best for terrace weathering course or roof tiles?
Tue Jun 18, 2013Total posts : 6
Arun
Arun
Topic: which one best for terrace weathering course or roof tiles?
Kindle explain which one best for terrace
weathering course(use lime,brick jalli,oil,etc) or cool roof tiles?
Please check the link http://www.argilcoolrooftiles.com/products.html is it true?
Tue Jun 18, 2013Post  #1
Dear Murgan
       In my view roof tile terracing is best option.
Wed Jun 19, 2013Post  #2
Arun
Arun
Dear Gupta,
Could you please explain to me the proper usage of roof tiles?
and best brand laying method?
Wed Jun 19, 2013Post  #3
Dear Murgan
       Tile terracing is a system of waterproofing on roof and brief description is as under
     1. Clean the top surface of roof with wire brush and broom.
2. Apply bitumen on roof i.e. bitumen painting on roof surface @ of 1.7 kg per sqm.
3. There are two ways that
a. Stick the polythene sheet on bitumen surface OR
b. The other option is directly lay the polythene sheet on the clean roof.
4. Apply mud mixed with bhusa 1'' thick on the polythene sheet.
5 Lay earth on the mud laid on roof by giving proper slope to drain rain water.
6. After that lay brick tiles/ clay tiles with mud on the rammed earth.
7. After laying the tiles the joints are grouted with cement mortar 1;3.
8. Clean the roof and tiles should be cement pointed.
Sat Jun 29, 2013Post  #4
Can we use "Ceramic tiles" in place of brick tiles. is there any harm.
Mon Jul 01, 2013Post  #5
Dear Panchal
              Yes, You can use ceramic tiles instead of brick tiles. These are costly and need much care as if use in rough manner can be damaged. Also take care when tiles surface is wet as it is some what slippery.
Sat Feb 08, 2014Post  #6
s.anbukuppusamy
s.anbukuppusamy
Abc weather proof. Tiles is best. For terrace..it act as a heat proof and water proof.it reflect the solar rays..white color abc weather proof tile is good for terrace.
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
1757
20152
1849
Water dripping and Damp patches after laying sunban tiles(igloo tiles) in terrace
Last answer on 8/5/2015 4:24:08 AM. by JAI PRAKASH. Forum started by Radhika
2771
5003
Weathering course
Last answer on 7/25/2014 9:42:13 PM. by JAI PRAKASH. Forum started by Radhika
4050
How to Apply Ceramic tiles on roof Terrace
Last answer on 12/3/2011 10:27:48 PM. by newtondisc. Forum started by Pooja Panchal
roofing on open terrace
2902
Terrace water proofing
3129
2197
Roof Weathering
Last answer on 1/12/2021 6:35:24 AM. by S L Gupta (Civil Engg). Forum started by Mohan
2305
2857
5175
1795
Wehave 93 years old tiled roof with norh face. Behind of this recently construct
Last answer on 5/1/2015 1:40:37 AM. by JAI PRAKASH. Forum started by balagangadhar
3912
2144
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
1608
Which tiles are best now .Plz tell me with price
Last answer on 3/14/2017 12:11:38 PM. by S L Gupta (Civil Engg). Forum started by Subbu
3396
nice elevation.......what v can use for roof tiles (on curve)
Last answer on 7/3/2020 11:40:59 PM. by S L Gupta (Civil Engg). Forum started by anil jaggi
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Roof Garden
Guideline for laying DPC
Cooper
