Home -> Forums -> Construction -> Bricks -> Is over burnt bricks are good for foundation work.
Tue Jan 15, 2013Total posts : 8
sunny420
sunny420
Topic: Is over burnt bricks are good for foundation work.
Hello sir,
Plzz guide me
Is over burnt bricks are good for foundation area work. that r also known as "Khangar" Bricks . Are they strong and recomendable for foundation construction work if the house is triple floor flat style...
Tue Jan 15, 2013Post  #1
Dear sunny
            There is differance between over brunt bricks and Khangar.Over brunt bricks are those which have proper shape but slightly over brunt having some blackish color but Kangar is vetrified have no shape and being porous and spongy in the process of over brunt, require more cement mortar and foundation become weak. As per engineering guide line slightly over brunt brick can be used but Kangar will not to be use at any cost for triple story building. Beside shape and size Kangar will not accept cement mortar as in case of first class brick.
Wed Nov 18, 2015Post  #2
Rohit Sharma
Rohit Sharma
 is second class brick ( also called darra) can be used in foundation? for 2 or 2.5 storey building of 100 square yards?
Thu Nov 19, 2015Post  #3
Dear Rohit Sharma
          How much you save in 25 laks by using 2nd class bricks. Secondly when you allow brick kiln owner for 2nd class he will certainly mix 3rd class after your supervision.
Fri Nov 20, 2015Post  #4
Rohit Sharma
Rohit Sharma
Thank you for your suggestion Sir, I will keep it in mind
Mon Nov 23, 2015Post  #5
Over burnt and Old bricks can be used in Foundation but not Khangar.
Fri Dec 04, 2015Post  #6
Rohit Sharma
Rohit Sharma
Post subject: bricks
I heard abot 4 kinds of bricks in punjab
Abbal, Darra, Pilli and khangar
is this darra which you call overburnt or second class brick?
Fri Dec 04, 2015Post  #7
Dear Sharma
      These are 2nd class bricks.
Fri Sep 07, 2018Post  #8
Thank you sir,
2350
1763
1668
3475
labour charges rates
2515
Cement
3457
9196
2251
Hello Sir,I am doing one interior project of a bank but some civil part I am fac
Last answer on 1/24/2022 9:12:12 PM. by JAI PRAKASH. Forum started by Gunjan
2224
New Construction
1398
I am planning to buy a residental 21*89 plot..is it good dimension??
Last answer on 2/25/2022 6:03:38 AM. by S L Gupta (Civil Engg). Forum started by KARAN KAPOOR
2894
Foundation Brick estimate
Last answer on 7/4/2020 2:12:13 AM. by Bs Dhiman. Forum started by Bs Dhiman
759
I am looking for a good SUV for all family of middle size
Last answer on 7/9/2021 8:32:03 AM. Forum started by Simon
7513
Brick Advice Urgent
52271
Curing for Brick Walls before and after Plastering
Last answer on 9/23/2013 11:50:55 AM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
4256
4950
1702
material requirememt question
Last answer on 12/26/2015 7:41:53 PM. by JAI PRAKASH. Forum started by sushantsah
2866
Bricks
3992
7513
Brick Advice Urgent
2880
Bricks
2794
brick calculation
2566
Cost of Brickwork
4895
2821
2350
3172
bricks
2014
3238
5135
Use of Solid Concrete Bricks
1625
1341
1846
1480
1797
2967
fly ash bricks
2230
1723
Designing
Designing a Foundation
Brick Arches
