Home -> Forums -> Construction -> Start Construction -> over head water tank crack repair
Sun Jan 25, 2015Total posts : 3
Arun
Arun
Topic: over head water tank crack repair
Find the attached file,how to repair the crack?
it's brick wall water tank.
Attachments: over head tank crack.jpg on Sun Jan 25, 2015,&n
Tue Jan 27, 2015Post  #1
u can use Silicon coating.
Tue Feb 03, 2015Post  #2
Prepare a paste of cement with "Dr. Fixit Liquid " and then fill the crack by Spatula. apply pressure to fill it properly. then apply primer and paint.
Wed Feb 04, 2015Post  #3
Post  #1
Dear Bauro
          Cracks must be repaired immediately when observed otherwise the life of structure will reduce causing structural failure. They not only weaken the building but spoil the beauty of walls also. This write up tells you about repair of cracks in plaster, RCC member, Brick walls, Floor and Fine Cracks.  See the link below
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
Delete
3387
1797
How to repair the suspension crack floor
Last answer on 2/4/2015 11:31:02 AM. by S L Gupta (Civil Engg). Forum started by BAURO
1966
Over Head Water Tank
3370
2897
2234
5055
5625
Over-Head water Tank
3368
4309
Overhead water tank - above head room roof
Last answer on 6/3/2013 3:24:57 PM. by muthuraj. Forum started by muthuraj
3119
2374
water tank
2185
2482
1727
1933
6579
7232
2 lakh litre water tank
1844
3296
3309
2133
2059
Vastu for Water Tank
How To Repair Cracks
Preventive
Shower
Shower Head - A Stylish Bath Experience
Shower heads shower the water over the top of your body just like rain water and give a delightful feeling to you. The..
Reasons of dampness
