Home -> Forums -> Construction -> Start Construction -> overhead tank
overhead tank
Mon Jun 25, 2012Total posts : 1
pallubc2
pallubc2
Topic: overhead tank
hello all,
i have both borewell water and corporation water . mine is an independent single house. suggest me on the overhead tanks and its connections. should i keep seperate tanks.
regards,
pallavi
Wed Jun 27, 2012Post  #1
Major Anil Kumar
Major Anil Kumar
Post subject: check out quality of water
Hi Pallavi,
1.In my opinion first check the water in any laboratory for its potability as per WHO standards. These test can be performed in lab's of either Engineering college or Public Health Engineering Departmental labs.
2.Secondly, check up for hardness of bore water and if hardness its quality and type of hardness, so that necessary softener can be installed.
3.Providing separate overhead tanks has no meaning as the outlet taps will be common. If you propose separate tap and so the pipe line the costing will be uneconomical and also the final usage of water will be for the common purpose.
4.Hard water will though non injurious to health, it leaves stain marks on the materials, produces less leather with soap, leaves dryness on skin and dulls the hairs luster.
 5. Water can be mixed after treatment for hardness and stored in common water tank.
Major Anil Kumar
Civil Engr, Chartered Engr, MIE
2647
1877
sir, My house overhead tank loation is north west, please suggest me.
Last answer on 1/1/2013 6:19:15 PM. by Pavan. Forum started by kuldeep
1437
I need help! How do I seal a leak from my overhead tank?
Last answer on 8/8/2017 11:57:23 AM. by S L Gupta (Civil Engg). Forum started by Arun
2388
1500
overhead tank
Last answer on 1/8/2015 11:56:53 PM. by JAI PRAKASH. Forum started by raghu6961
1690
Sir, my house overhead tank location is north east corner and middle of house, b
Last answer on 1/2/2013 12:48:34 PM. by kuldeep. Forum started by kuldeep
1918
Water tank
Last answer on 10/1/2014 8:18:00 PM. by JAI PRAKASH. Forum started by karthik
10028
OVERHEAD WATER STORAGE TANK
Last answer on 3/13/2013 1:37:46 AM. by Purvi Panchal. Forum started by Purvi Panchal
5103
vatu tips for terrace garden
Last answer on 11/26/2011 2:03:36 PM. by Robert Monroe. Forum started by Rishiv Garg
2538
underground tank
Last answer on 2/26/2013 8:10:29 PM. by Pavan. Forum started by Subramani P
4311
Overhead water tank - above head room roof
Last answer on 6/3/2013 3:24:57 PM. by muthuraj. Forum started by muthuraj
2322
Overhead water tank design
Last answer on 10/26/2016 12:48:05 PM. by S L Gupta (Civil Engg). Forum started by Rakesh
1967
Over Head Water Tank
2175
3457
Last answer on 2/4/2022 11:19:50 PM. by Vaasku. Forum started by jayakrishnan
3056
what is the disadvantages of overhead watertank in northeast area?
Last answer on 5/7/2011 5:12:00 PM. by sabina vanjani. Forum started by alok
5055
1844
7232
2 lakh litre water tank
3310
Vastu for Water Tank
Preventive
Reasons of dampness
Sewerage
Sewerage & Plumbing System
Importance
