Home -> Forums -> Construction -> Steel -> overlap length to steel
Fri Apr 11, 2014Total posts : 4
shaik khaja nayab rasool
Topic: overlap length to steel
hai..what is the minimum and maximam overlap length to extend the steei bars in beams,columns.......for different type of steel dia bars
Sun Apr 13, 2014Post  #1
Post subject: Lap lengths of various MS steel bars
Dear Rasool: An overlap of about 50 times the diameter of the steel bat should be provided. This principle is referred to as 50D.
The Lap lengths of various diameters of steel bars is as follows:
8mm:   Lap should be 400mm   = 40cm   = 16"   approx.
12mm: Lap should be 600mm   = 60cm   = 24"   approx.
16mm: Lap should be 800mm   = 80cm   = 31.5" approx.
20mm: Lap should be 1000mm = 100cm = 39.5" approx.
25mm: Lap should be 1250mm = 125cm = 49.5" approx.
Laps of neighboring steel bars should be staggered and not be provided at one level/line. At one cross section, a maximum of 50% bars should be lapped.
I hope it helps.
Mon Jun 08, 2015Post  #2
kavitha
kavitha
Post subject: over lapping length in bars
Can i know on what basis the lap lengths you have shared..also can you tell me the code which is talking about the laps in steel bars.
Tue Jun 09, 2015Post  #3
See for over lap
Overlapping in Steel Bars in Reinforced Cement Concrete
There should be no joints in steel bars used for RCC work. If it is necessary to use small length steel bars, proper overlap should be given.
The joints of bars should be welded in case the diameter of bars is more than 36 mm. Overlapping of bars should not touch each other and they should be kept apart. Where it is not possible, overlapping bars should be bound together at intervals not exceeding twice the diameter of such bars with two strands of steel wires trusted tight. The overlap should be staggered for different bars. The length of overlap should not be less than 50 times the diameter of steel bar.
Tue Jun 16, 2015Post  #4
Superb Topic.
15583
1304
2037
2708
2303
2034
2217
2899
RCC Roof
4331
2539
1780
4940
COLUMN AND STEEL DESIGN
4940
3380
Square 4 side Pyramid Frame by MS Steel for RCC.
Last answer on 7/29/2014 2:33:14 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Singh
3161
Laping length requirement
2268
Dear Sir
Last answer on 3/9/2013 11:21:57 AM. by S L Gupta (Civil Engg). Forum started by Sreenivas Kumar
2855
Stair case
Last answer on 9/15/2021 12:40:33 AM. by Amit Hasija. Forum started by Hidayath
1811
sir i need 6 marla house mapsize;37 width43 length
Last answer on 12/10/2014 10:02:46 AM. by seema tyagi. Forum started by Arshad Ehsan
2132
what are requirements of RCC cantilever length?
Last answer on 12/24/2014 11:46:06 AM. by S L Gupta (Civil Engg). Forum started by syed basha
2685
steel requirment
15583
1992
Residential complex
4370
RCC Columns
3239
7480
Bar Bending Schedule Software
2523
steel
29942
2613
9363
2262
Current iron rod price
2606
1885
Steel Erectors
2382
3268
2161
2539
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
