parts of concrete and size.
Tue Mar 15, 2011Total posts : 2
kanwer sajjad
kanwer sajjad
Topic: parts of concrete and size.
Wed Mar 16, 2011Post  #1
Nikita
Nikita
Post subject: Parts of concrete.
Hello Kanwer,
Cement concrete includes:
  • Portland cement
  • Water
  • Coarse aggregate consisting comprising gravel, crushed  stones
  • Fine aggregate consisiting of coarse sand.
These elements mixed in a specified proportion and perform 'Cement Concrete'
Regards:
Nikita.
Wed Mar 16, 2011Post  #2
Dear Kanwer
             The cement concrete mix have three ingradient which includes
            1. Cement
             2. coarse aggrigate i.e Bazri or gravel or crushed stone 12mm to 20 mm size.
   3. Fine aggrigate i.e coarse sand having finness modulous more than 2.4 and silt contents should be less than 4%.
The ratio is according to requirement i.e M10,M15, M20, M25.
Last answer on 1/7/2022 1:25:49 AM. by Girish. Forum started by Girish
1767
1460
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
2025
1877
home panting work part of 30 years expart.ple cal me 9239293464
Last answer on 3/31/2011 11:51:03 AM. Forum started by sankarkarmakar
2475
what is the best way to split area in 16 parts and find elder next..children
Last answer on 10/1/2021 3:32:03 AM. by RadyGoldy. Forum started by D.Ramachandran
2165
am happy to be part of this company.
Last answer on 6/19/2011 10:32:37 PM. Forum started by kunlex
1776
7 year boy should study in which part of house.second best option also
Last answer on 9/12/2011 8:32:04 PM. Forum started by ricky singh
2852
Last answer on 9/23/2013 11:39:54 AM. by S L Gupta (Civil Engg). Forum started by Neha sanghvi
3456
3470
Cost of concrete walls
3838
please make house plan fo attached plot layout
Last answer on 7/10/2012 1:57:21 PM. by Raji. Forum started by Dinesh Daiya
20124
2107
1619
2223
zero slump concrete
1785
3433
15
17
Parts of an arch
Definition of parts of an arch with diagram. Parts of an arch: Voussoir, crown, Keystone, Pier, Intrados, Extrados, Im..
Cement
Cement Concrete
Dormer
Dormer is a building block which projects from sloping roof. This articles has more detailed information about dormer.
Garage
Garage door parts
Understanding garage door parts can help you in choosing the style of garage door, maintaining, and increasing the life.
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Bathroom Accessories Part-4
