Home -> Forums -> Construction -> Start Construction -> pg building
pg building
Thu Jul 11, 2013Total posts : 4
Manveer
Manveer
Topic: pg building
my plot size is 28x52... i want to make paying guest in that area.. in total i want 12 rooms with small washrooms and small kitchen sets.i want 3 floors with a big kitchen on the ground floor.. and 3 rooms and then 4 room set on the first floor and then 4 room set on the second floor and a big water tank and a room on the top floor... i don't want any cupboard in the rooms..no good quality flooring just the cheapest tile will do .. same n the case with bathroom fittings...kitchen just need kota stone shelves and cheap tile on the wall.. then snwcem paint everywhere in the whole house... the doors i can buy the old onesand angle grills...pillars may be needed for the building.. as it is in the closely ominated area..i just wanted to know the total cost of construction.. i want the building in the least possible expense as possible...
thanks..
Thu Jul 11, 2013Post  #1
Dear Manveer
1.         The cost of construction is based on the plan ,elevation and specification used in the construction of building.  cost is also co related with types of foundation. For accurate costing you can e-mail at support@gharexpert.com for detail estimate.See the link below.
Thu Jul 11, 2013Post  #2
Manveer
Manveer
Post subject: foundation
foundation need not to be that strong.. just as the normal foundation in a home....like normal pillarswith wall and then the lenter...in all i want to spend least amount on the building...
Thu Jul 11, 2013Post  #3
Manveer
Manveer
Post subject: elevation
the elevationand specification also doesn't matter.. i want the simplest structure...i just wanted to know the approximate cost for the house..
Fri Jul 12, 2013Post  #4
Dear Manveer
          For simple specification you can use Estimator in gharexpert.com The service is free of cost. You have fill up the area to be constructed and get the cost of construction.
1332
PG Construction
Last answer on 3/5/2016 9:51:28 PM. by JAI PRAKASH. Forum started by Prasanna
2258
B.Arch (I.D.)
Last answer on 7/31/2009 11:00:37 PM. Forum started by Aamir
1685
How many floors will be allowed
Last answer on 11/7/2016 3:00:37 PM. by S L Gupta (Civil Engg). Forum started by Lakshmi
2020
3511
2135
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
3311
GFRC Construction
2857
Construction of new office bilding
Last answer on 2/22/2022 6:39:38 AM. by Anupam Anurag. Forum started by sushil singh
1979
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
1554
I want to demolish a double storyed building and reconstruct a G 4 Building on a
Last answer on 1/31/2016 11:03:50 PM. by JAI PRAKASH. Forum started by Amitava Bandyopadhyay
1884
2040
6158
2338
3445
2846
As per Vastu, Can we make building with North-West corner extended with other pa
Last answer on 6/8/2012 9:37:13 PM. by Maanoj. Forum started by M.J.Khan
1874
i really like this building and will like to know if i can get the plan for the
Last answer on 3/4/2012 7:48:08 PM. by polamset. Forum started by ralph
2643
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
2483
3310
3322
4453
4028
2251
2728
4237
5213
2397
2322
2464
2143
3217
2076
12548
2193
2034
2754
Orientation
Orientation of Building
Cupola Proportions
Tips for cupola proportions
Fire
How to Design a Garage
Comparison
