Home -> Forums -> Construction -> Earth -> pile work
pile work
Wed Apr 09, 2014Total posts : 2
Topic: pile work
HI,
I am going to dig  earth  by pile for constructing  home but there is water in ground  that start from 3 feet from ground level i don't know  is it drainage water or neighbour water tanks water or ground water.
It is  very clear  that  i have lots of water in my colony that start very early.
My question how can i fill material ( mixture of sand cement stone) as we drain it it again come.
how we can give strong pile rcc .
Fri Apr 11, 2014Post  #1
Dear Paresh
                 It is better to take advice from local engineer, who can give advice after visiting the site.
Sat Apr 12, 2014Post  #2
SANKARDAS BANERJEE
SANKARDAS BANERJEE
Post subject: Water logging site.
Frist you take information about the water table of your area, which may available from any tube well boring contractor, then if necessary  make arrange for soil test and do
 all according to the advice and recommendation of a soil test report.
Earth-Construction Questions (23)
1646
PILING WORK AND PARKING LOT BUILDING ESTIMATE
Last answer on 7/6/2016 11:25:38 AM. by S L Gupta (Civil Engg). Forum started by CHANDRAKANT
2510
PILING in a soft soil
Last answer on 7/9/2012 3:38:08 PM. by S L Gupta (Civil Engg). Forum started by mangeshghule
1994
Minimum thickness of Pile Caps
Last answer on 11/6/2016 1:21:02 AM. Forum started by Pritam Thakur
1537
borewell drilling effect to pile colom
Last answer on 4/27/2014 3:44:03 AM. by serin. Forum started by paresh
2509
Pile Foundation
2321
1967
Last answer on 5/20/2010 8:30:01 PM. by S L Gupta (Civil Engg). Forum started by sudhir
1644
Sr I wont to bild 600sq ft on piled house bicose my land is river front 8to10ft
Last answer on 10/11/2015 8:04:12 PM. by JAI PRAKASH. Forum started by ismail
3397
Bathroom Cleaning Tips
1820
3105
Last answer on 10/5/2020 10:59:59 PM. by S L Gupta (Civil Engg). Forum started by DEVANSU
4443
lobar work quantity
9040
Absence of Plinth Beam
Last answer on 7/3/2020 9:29:19 PM. by Pritam Thakur. Forum started by Pritam Thakur
2780
Plaster work
1762
1667
2515
Cement
2157
1836
1709
Det fører til overstriding i Tillegg til utvidet knusende
Last answer on 1/20/2017 2:09:02 PM. Forum started by farofaschafer
1661
Rainwater Saving Earth pits
Last answer on 9/28/2015 11:17:59 AM. by S L Gupta (Civil Engg). Forum started by Bharat Kumar
1537
2482
map design
Last answer on 4/14/2014 11:28:10 AM. by S L Gupta (Civil Engg). Forum started by sushil
Checklist
Checklist for Painting Work
Surface
Preliminary
Wrought
Wrought Iron Furniture
Wrought iron furniture is perfect blend of art and beauty. It’s one of the most popular choices of service providers a..
