Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> pillar form work
pillar form work
Mon Dec 28, 2015Total posts : 2
Rohit Sharma
Rohit Sharma
Topic: pillar form work
Hello,
My contractor said that he can used steel shuttering or wooden planks to fill 9"by9" pillars/piers.  But he recommended wooden planks because the external of pillar will be rough in case he use wood planks and this rough facings of pillars will make better bonding with walls as compared to smooth and plain facings in case of steel shuttering.
What do you recommend?
Mon Dec 28, 2015Post  #1
Dear Rohit Sharma
            Use proper form work i.e. FRAMA of steel for filling the columns. In plank shuttering strength of concrete reduces. If you want rough surface than after removal of form work apply wire brush on the surface for giving rough surface.
Tue Dec 29, 2015Post  #2
Use steel frames only.
3607
18434
4429
2066
Can u please tell me what should be the form and structure of a drawing room
Last answer on 9/19/2011 8:37:44 PM. Forum started by Ruchi Shrivastava
3607
3397
Bathroom Cleaning Tips
2757
Last answer on 8/26/2013 1:23:28 PM. by S L Gupta (Civil Engg). Forum started by ragha
1362
SirAfter construction of the basement slab, can the pillar work for the ground f
Last answer on 9/4/2017 12:35:46 AM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
13852
Pillar & plinth beam frame work avoiding stone foundation
Last answer on 5/11/2017 11:22:09 AM. by S L Gupta (Civil Engg). Forum started by tp_bangalore
1820
2694
4387
9225
pillar size in distacce
3237
22039
what is the full form of C.B. mentioned in the plan?
Last answer on 11/13/2014 6:29:10 PM. by JAI PRAKASH. Forum started by Navaz
1764
Window Size
Last answer on 2/21/2014 11:50:13 AM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1645
Sr I wont to bild 600sq ft on piled house bicose my land is river front 8to10ft
Last answer on 10/11/2015 8:04:12 PM. by JAI PRAKASH. Forum started by ismail
Shuttering Plywood
Last answer on 12/4/2011 6:16:40 PM. Forum started by Girish
5811
3792
9884
2670
4627
4143
2865
5006
3655
1864
2800
2610
2372
2462
2638
1807
3607
6254
Brick Pillar
Centering
What are the specifications for preparation of tiles for POP tiles ceiling?
Tiles of POP reinforced with hessain cloth are prepared in suitable sizes.The maximum size of the tiles is limited to ..
Checklist
Checklist for Painting Work
Surface
Preliminary
