Home -> Forums -> Construction -> Pillar Work -> pillar size in distacce
Mon Sep 21, 2015Total posts : 14
jaybiswa
jaybiswa
Topic: pillar size in distacce
i want to know  pillar size required for the distance of  16 feet between of
two pillar
Tue Sep 22, 2015Post  #1
Are you talking about the column size or the latak (Cantilever) between them.
Tue Sep 22, 2015Post  #2
Dear Jay
         You want to know the size of column or pillar. The size of column is design according to load coming on pillar. However in general the size keep the size 9''x 12'' with MS Steel bars 6nos 16 mm diameter.
Wed Apr 20, 2016Post  #3
sunil kumar
sunil kumar
Post subject: pillar and beam size in distance
I want to know pillar and beam size required for the distance  20 ft between two pillar. in future i built 3 storage building.
Thu Apr 21, 2016Post  #4
Dear Kumar
           It is better to take structural advice as building is 3 or 4 story. The size of column is design according to load coming on pillar and safety from earth quack etc.
Sat Feb 25, 2017Post  #5
ravinder yadav
ravinder yadav
i have to make my house of size 16 ft by 60ft how many pillar i have to construct if its one floor building
Mon Feb 27, 2017Post  #6
Dear Yadav,
        The numbers and size of columns/ pillars depends on the plan of the building  not on size of building.
Wed May 03, 2017Post  #7
Pandu
Pandu
Post subject: Pillar distance and size
Hi Gupta sir,
There is huge knwoledge bank in the site about the House construction.
I need small help.
I am constructing House of  27" x 50 sft. Pillar size if 9x12 with 4 - 16 mm rods and 2 - 12 mm rods. In hall the distance between piller to pillar is 16ft (Horizantal) and vertical  9.5ft. Pls suggest is it fine. If it is fine how many floor i can construct.
Attachments: Plan 1 (1).pdf Wed May 03, 2017,&n
Thu May 04, 2017Post  #8
          The size and MS Steel used in RCC column is designed on basis of load bear by the column.Up to 2 story building i.e. ground and first floor the steel bars given seems to be correct. Use cement concrete mix 1;1.5;3 in the column duly machine mixed and vibrated.
Mon May 08, 2017Post  #9
Pandu
Pandu
Thank you very much Gupta sir for really quick revert and guidance.
Your advice means a lot for me, as i was little confused about the distance between the pillar (16 sft).
Engineer said the plan is for G+2, though at present i dont have any plan for third floor. Engineer saying that as the vertical pillar  are of below 10 ft distance there is no problem.
Regards.
Mon May 08, 2017Post  #10
Pandu
Pandu
I have attached the plan for your kind perusal.
Attachments: Plan 1 (1).pdf Mon May 08, 2017,&n
Mon May 08, 2017Post  #11
      I have already replied your question, what is further query. Write in detail what type of information do you need.
Mon May 08, 2017Post  #12
Pandu
Pandu
Sorry to bother you.
Main query as to number of floors and steel rods bearing capacity has been clarified by you.
When i checked other houses in the locality their hall size pillar to pillar distance is about 14 - 15 ft only,  where as in my plan it has been given as 16 ft.
That is the only issue with the plan. As per engineer it is for G+ 2.
Brief of plan:
Pillar depth up to plinth beam is more than 9 ft. (Footings around 18 inch)
Pillar size 9 X 12 ( 16 MM x 4. 12 MM x2, 8 mm rings)
Plinth beam size : 9x12 ( Hall and bedroom- 16 mm (2) bottom and 2x 12 mm top)and for kicthen etc ( all 12 mm) - for room sizes plan is already attached.
top beam ( 16 mm (3) bottom and 2x 12 mm top)
Mon May 08, 2017Post  #13
        As already stated that
        It is better to take structural advice for building construction. The size of column is design according to load coming on pillar and safety from earth quack etc.This which you are doing is hit and trial method. If you have constructed the house than do not bother, live in the house happily.
Mon May 08, 2017Post  #14
Pandu
Pandu
The construction is at plinth beam only sir, just got doubt about the distance of pillar as i found it is little bit extra distance (2 ft) .
Thank you very much sir for your valuable advice.
3771
small size plot, pillar location, size and number of required pillars, floor plan
Last answer on 3/20/2014 2:49:26 PM. Forum started by basbrem
4431
2695
3134
1528
Guide me
2890
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by SAROJINI
65239
4389
3609
1683
Home Construction
Last answer on 7/3/2020 11:12:41 PM. Forum started by Rajesh
20402
What Should be the size of pillar for the distance of 14 feet for two floor house?
Last answer on 11/20/2010 9:47:00 PM. by S L Gupta (Civil Engg). Forum started by sureshdy
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
901
Hi All,I bought a house which is already built G 1.The house consists of 12 pill
Last answer on 8/1/2018 11:51:13 PM. by S L Gupta (Civil Engg). Forum started by vinay
947
Last answer on 8/1/2018 11:52:28 PM. by S L Gupta (Civil Engg). Forum started by vinay
4037
2006
I am constructing a home and the area size is 28 X 21. It has 9 Pillars each has
Last answer on 7/3/2020 11:49:45 PM. by KV. Forum started by KV
4039
4388
32561
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
4037
42125
12462
First floor construction
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9195
2823
2695
1993
2208
3161
Laping length requirement
Brick Pillar
Right size cupola
What is the recommended size of wooden boards?
Maximum length of the board should be 180 cm.
What is binding wire
