Home -> Forums -> Construction -> Ground work -> What is the plinth Beam properties for Ground +3 residential building?
Fri Oct 11, 2013Total posts : 2
ananth
ananth
Topic: What is the plinth Beam properties for Ground +3 residential building?
We are constructing the plinth beam for Ground+3 residential building.
The Ground (1500sqf) and First(1600 sqf) ,Second(1600sqf) and Third(1600sqf).
What is the RCC ratio? I need very Strong one.
What is the width and height?
What is the steel Size? Recommended one?
Please advice.
Thanks,
Ananth
Mon Oct 14, 2013Post  #1
Post subject: the plinth Beam properties for Ground +3 residen...
Dear Ananth, Hello...! If you are going to construct a building G +3, Kindly Get its Structural design ,according to plans of all floors & load bearing capacity of soil,by a Structural Engineer.It is very much needed for such type of constructions. regards...                  " AVOID RISK,   FOLLOW RULES,   ENSURE SAFETY."
Mon Oct 14, 2013Post  #2
Dear Ananth
         For such heavy structure, you need proper design. So it is advisable take structure design from any structural engineer as also stated by Sh Navneet Jharia.
4665
Regarding Beam
Help required for construction of basement+ stilt+ 3 floors on 205 sqyd plot in huda gurgaon sector
Last answer on 3/16/2017 10:24:00 PM. Forum started by Mukesh
9042
Absence of Plinth Beam
Last answer on 7/3/2020 9:29:19 PM. by Pritam Thakur. Forum started by Pritam Thakur
3129
Plinth beam at ground level
3884
stone foundation
1961
how to do gas piping for a residential ground floor independent building should
Last answer on 12/26/2011 7:59:32 PM. by S L Gupta (Civil Engg). Forum started by elizabeth
2995
5086
855
Kindly refer my attachment,For G 2 residential building, M15 grade used ,for roo
Last answer on 7/4/2020 2:29:32 AM. by S L Gupta (Civil Engg). Forum started by Sathya
928
Last answer on 7/2/2020 9:41:30 PM. by S L Gupta (Civil Engg). Forum started by Sathya
9197
8653
2573
2125
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
2279
Plumbing works
2017
14602
5692
1846
2998
8162
software
3901
2731
1834
lanterns
3134
false ceiling
2246
about construction
1787
4155
Cement Coba
3077
Water Harvesting System
1677
1758
water tank
2059
1761
1634
Pool construction cost
1997
2739
Regarding roof beam
2061
Fire Stair case
2646
2374
super structure
Preliminary
Cedar Wood
Centering
Orientation
Orientation of Building
Pool Pumps
Cupola Proportions
Tips for cupola proportions
