Fri Jan 24, 2014 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Bansal Both Tata & jindal Are good with Unik fittings.
Fri Jan 24, 2014 | Post #2 | Sunny Bansal
Join date: Jun 2009 | Post subject: Dear Sir (S.L. Gupta Ji)
I live in rohtak. Most of the people faced leakage problem because of rust with GI pipes like Jindal & Tata. Same problem i also faced in my present house. In most of buildings, GI pipes crossed through RCC from one side to another.
Most of the Architect recommends Kitec Pipes here to avoid rust & leakage. Is it better than GI or best alternate for longterm than GI? No body knows about the disadvantage of Kitec MLC pipe with Brass Connections.
Which one is suitable among them for underground/wall fittings or open installation (from shaft etc.(Half underground/Half open)). Please suggest solution to prevent GI pipe from rust. As you suggest in last post, GI is better which one is best among TATA C/Jindal C?
Please clear our doubt and help everyone. Thanks for your valuable suggestions. | |
Sat Jan 25, 2014 | Post #3 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Bansal UPVC pipes are being increasingly used
now days because of a number of advantages such as light in weight yet
strong, easy to transport, good flow, corrosion resistant, unaffected by
fungi or bacteria and resistant to wide range of chemicals etc.
G.I.
pipe hold good in lying in open i.e. on the surface of wall or floor
where as UPVC pipes need special care at the time of laying the pipe
line to save it from breakage and not hold good in open. UPVC pipes are
good for water temperature ranging from 1 to 45 degree centigrade, at
higher temperature; the strength of pipes reduces where as G.I. pipes
hold well on all temperature. For embedding pipe in floor or walls, it should be painted with anti corrosive bitumastic paints of approved make.Care should be taken that pipe should not come in contact lime mortar or lime concrete as the pipe is affected by lime.
Thu Apr 21, 2016 | Post #4 | ravi
hi everyonewill like to share my experience with you all. Pex/Al/PEx pipes are the best when it comes to plumbing.be sure that you use compression brass fittings with them . GI pipes are no longer used in the wetern countries because of the various problems faced with them like leakges.corrosion etc. PPR and Cpvc are gradually fading out since the quality issues and bonding of the joints has become a major issues, apart from that algae formation is there since its a single layer pipe that is why i would recommend PEX/AL/PEX pipes 1. look for a food grade certification - only Astral and Sant rifeng have them 2. go for PEX/AL/PEX and not PEX/AL/PE or PERT pipes worldwide only pex is used 3. go for DZR brass fittings only 4. Go for a company which is certified by NSF , no point going in for ISI since ISI has taken its standard from ASTM i would rate three companies as the best ones in India - Sant- Rifeng(Rifeng is the biggest player world wide ) 2. Upanor - again a very good company 3. Vega kindly dont try the local ones kitec/jindal/vectus etc since they are using very cheap material whose quality is not good . A faulty plumbing and play havoc with your house | |
Questions (39) | |
4949 views | 1 answers | Last answer on 6/24/2021 1:12:48 PM. by S L Gupta (Civil Engg). Forum started by sunny420 | 9174 views | 1 answers | Last answer on 4/19/2010 4:03:39 PM. by S L Gupta (Civil Engg). Forum started by narender | 2942 views | 2 answers | Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI |
| 1781 views | 2 answers | Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma | 15582 views | 2 answers | Last answer on 7/26/2021 2:26:58 AM. by paresh. Forum started by paresh | 2100 views | 1 answers | Last answer on 1/27/2015 7:24:32 PM. by JAI PRAKASH. Forum started by R. Ramachandran | 1989 views | 1 answers | Last answer on 6/8/2016 1:29:11 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA | 2083 views | 2 answers | Last answer on 7/9/2018 12:35:54 AM. by S L Gupta (Civil Engg). Forum started by Rahul | 3072 views | 3 answers | Last answer on 7/2/2020 10:08:44 PM. by EvaR. Forum started by paresh | 1826 views | 1 answers | Last answer on 7/18/2016 11:26:37 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE | 3206 views | 3 answers | Last answer on 7/4/2020 2:34:09 AM. by S L Gupta (Civil Engg). Forum started by paresh | 3805 views | 1 answers | Last answer on 11/3/2011 7:34:44 PM. by S L Gupta (Civil Engg). Forum started by Naveen | 1960 views | 1 answers | Last answer on 12/26/2011 7:59:32 PM. by S L Gupta (Civil Engg). Forum started by elizabeth | 2241 views | 1 answers | Last answer on 12/6/2010 1:50:39 PM. by S L Gupta (Civil Engg). Forum started by bipin brahmbhatt | 2570 views | 1 answers | Last answer on 4/12/2017 12:52:16 PM. by S L Gupta (Civil Engg). Forum started by Vandana Joshil | 2859 views | 1 answers | Last answer on 2/18/2013 11:37:36 AM. by S L Gupta (Civil Engg). Forum started by sunny420 | 2898 views | 2 answers | Last answer on 7/4/2020 12:19:59 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL | 2061 views | 1 answers | Last answer on 8/16/2013 4:29:58 PM. by S L Gupta (Civil Engg). Forum started by mahender | 1780 views | 1 answers | Last answer on 12/27/2020 6:52:53 AM. by S L Gupta (Civil Engg). Forum started by sukamalroy | 4 views | 0 answers | Last answer on 12/21/2024 12:29:49 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:40 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:32 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:29:24 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:29:18 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:29:12 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:29:05 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:28:58 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:51 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:44 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:28:38 AM. Forum started by rupeshji | 2 views | 0 answers | Last answer on 12/21/2024 12:28:31 AM. Forum started by rupeshji | 5 views | 0 answers | Last answer on 12/21/2024 12:28:24 AM. Forum started by rupeshji | 6 views | 0 answers | Last answer on 12/21/2024 12:28:18 AM. Forum started by rupeshji | 7 views | 0 answers | Last answer on 12/21/2024 12:28:10 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:28:03 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:56 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:22 AM. Forum started by rupeshji | 3 views | 0 answers | Last answer on 12/21/2024 12:27:16 AM. Forum started by rupeshji | 4 views | 0 answers | Last answer on 12/21/2024 12:27:08 AM. Forum started by rupeshji |
