Plumbing
Sun Jul 14, 2013
chrome
Topic: plumbing .. multistory ..water distrubution issue
hi
i live in on 3rd floor of a apartment.
we have a overhead tank , water to which is pumped from a ground tank.
Now the water is supplied to all 3 floors via one pipe taken from the overhead tank.
if all the taps on lower floors are open then water never accumulates in the pipe to reach my floor.
water just passes vertically and doesn't enter the horizontal outlet for my floor
is there any simple solution available as this might be a common phenomenon in multi-story apartments where water supply is limited.
thanks
Wed Jul 17, 2013
You should take separate supply line for your floor.
3397
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
2223
how to calculate plumbing material for any project
Last answer on 10/5/2014 11:19:25 PM. by
2494
Last answer on 7/3/2020 11:09:51 PM. by
hb
vnkesavan
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by
Arun
2279
Plumbing works
Last answer on 7/3/2020 10:42:29 PM. by
manjula
2014
space parameter for sanitary fittings
Last answer on 1/23/2016 8:28:13 PM. by
sandeep yadav
2132
plumbing
Last answer on 7/3/2019 12:32:56 AM. by
PLUMBING
Last answer on 6/8/2016 1:29:11 PM. by
Last answer on 7/18/2016 11:26:37 AM. by
1959
Last answer on 8/8/2016 2:21:56 PM. by
Balu Menon
2466
Last answer on 6/24/2013 3:10:11 PM. by
kk
2592
JOINERY WORKS
Last answer on 12/11/2013 11:18:00 AM. by
Last answer on 4/11/2017 11:10:57 AM. by
2016
Last answer on 7/4/2020 2:02:19 AM. by
brigith jose dopson
bibhas naik
3370
Last answer on 7/3/2020 11:28:14 PM. by
Y Mitran
8419
Roof Beam crack
Last answer on 7/3/2020 11:35:51 PM. by
Arun
2911
RCC ROOF LEAKAGE
Last answer on 12/5/2012 1:40:32 PM. by
sivarajen
2047
Are there are issues to paint a newly constructed house or is it better to wait
Last answer on 1/30/2013 11:36:55 AM. by
aiyer
1993
Can some one advice on the issues involved in designing a double stored roof wit
Last answer on 1/29/2010 6:25:52 PM. by
Anil Kumar Sood
6270
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
3114
Hot Water Tank
Last answer on 1/9/2021 1:51:22 PM. by
Fox
Kanhaiya
2914
Sand in Water
Last answer on 12/31/2020 1:56:57 AM. by
yogiagarwal
Kanhaiya
3380
Diverters for Bathroom
Last answer on 11/4/2020 4:13:51 AM. by
perryjoseph
2561
Last answer on 7/4/2020 3:36:21 AM. Forum started by
pallubc2
2145
Last answer on 7/4/2020 2:51:01 AM. by
Hema
40516
Last answer on 7/4/2020 2:50:25 AM. by
har
2083
GI pipe Vs CPVC pipeline
Last answer on 7/9/2018 12:35:54 AM. by
Rahul
2931
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
1755
Last answer on 4/22/2016 11:37:09 AM. by
jameel5
2080
Toilets
Last answer on 7/26/2015 4:31:26 AM. by
sandeep yadav
sandeep yadav
1988
Wall mounted cummod vs normal
Last answer on 7/2/2014 11:29:45 PM. by
awdhesh
5055
mohammed sadhiq ali
2775
Last answer on 1/25/2014 12:56:57 PM. by
Last answer on 5/16/2013 2:56:28 PM. by
sam_m400
3074
Swimming pool
Last answer on 10/30/2012 12:08:21 PM. by
rajesh
2541
water softner
pallubc2
2681
commode type and flush type
Last answer on 5/26/2012 9:05:44 AM. by
pallubc2
4193
to shut off water to house
Last answer on 3/28/2011 9:36:11 PM. by
chris
chris
Checklist for Plumbing
Sewerage & Plumbing System
Which are space parameters for plumbing and sanitary fittings?
The following are various space parameters for plumbing and sanitary fitting:
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
