Home -> Forums -> Construction -> Steel -> polaad steel tata tiscon vs jindal steel
Thu Jun 05, 2014Total posts : 2
Topic: polaad steel tata tiscon vs jindal steel
Hi
how is  polaad steel  brand  as compare to jindal and tata as this both two is manufactured with fresh steel.
what should be steel rebar overlapping length in column.
Fri Jun 06, 2014Post  #1
Dear Paresh
      The overlap length should be 50 x diameter of bar for steel bars see link below.
http://www.gharexpert.com/articles/Steel-1021/Type-Steel-Bars_0.aspx
http://www.gharexpert.com/articles/Steel-2018/TMT-Bars-Thermo-Mechanically-Treated-Bars-_0.aspx
Fri Mar 20, 2015Post  #2
Yes you can go with polaad  it is good and cheap. almost same quality
4950
3073
Steel
2898
RCC Roof
3207
steel
2860
Selection of Steel for home construction
Last answer on 2/18/2013 11:37:36 AM. by S L Gupta (Civil Engg). Forum started by sunny420
4331
21330
how much cement is required for 100 sq wall for plastering and brick work.
Last answer on 3/14/2013 2:12:10 PM. by S L Gupta (Civil Engg). Forum started by paresh
2216
2467
Saria and cement
2300
Steel prices Rathi/ Tata
Last answer on 2/22/2013 12:09:25 PM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
13267
Steel Type
4939
COLUMN AND STEEL DESIGN
4939
3903
construction of 1st floor
6356
2692
302 vs 304 grade steel for ralling
Last answer on 3/20/2015 9:55:35 PM. by JAI PRAKASH. Forum started by paresh
2910
2087
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
1836
chick door
2685
steel requirment
1992
Residential complex
4370
RCC Columns
3238
7479
Bar Bending Schedule Software
2522
steel
29942
2613
9362
2261
Current iron rod price
2606
1885
Steel Erectors
2382
3268
13772
overlap length to steel
2160
2539
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
