Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> position of partition wall
Sat Feb 20, 2016Total posts : 3
ani
ani
Topic: position of partition wall
Hi!, Thanks to all who are going through my simple question. In my floor plan the partition walls in the Gr. and in the 1st floor are not in a straight line. Is it  necessary to put the partition walls in the 1st floor as it is laid in the Gr. floor ? If not doing so (i.e., not laying in perpendicular line in both the floors) then do the partition wall(s) on the 1st floor produce extra load on the Gr. floor ?
 Please give your valuable suggestions . Thanks.
Wed Feb 24, 2016Post  #1
Dear Ani
      For laying partition wall at first floor on RCC slab, lay extra MS steel bars under the proposed partition walls.
Wed Feb 24, 2016Post  #2
ani
ani
Thanks a lot. I'll follow your advice.
Sat Mar 05, 2016Post  #3
Take an extra beam below it as suggested.
1525
3237
3391
plz tell me ideal position of dental chair n patient position in east facing den
Last answer on 7/3/2020 11:54:24 PM. Forum started by dr mona
4938
I want design for glass partition between Drawing room and lobby.Dimensions are
Last answer on 5/12/2015 2:43:34 AM. by JAI PRAKASH. Forum started by ravneet sidhu
3287
i want living room partition idea's my room size is 10.5 x 24.7
Last answer on 8/4/2010 10:11:07 PM. by sunilrathi86. Forum started by varu
2815
doors on 4.5"partition walls
Last answer on 5/17/2010 7:19:02 PM. by Ramkumar G Krish. Forum started by mohan
2530
Position of Kalpavirkha to be planted in east facing house & boring position of
Last answer on 7/3/2020 10:44:47 PM. Forum started by RAJ KUMAR KALIA
2849
1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Last answer on 11/1/2015 6:50:49 PM. by JAI PRAKASH. Forum started by vinu
1844
3935
load bearing walls
Last answer on 12/7/2020 12:04:44 AM. by mohan. Forum started by mohan
3017
E-Boards
Last answer on 12/31/2020 2:26:39 AM. by S.Krishnan. Forum started by madduri sundar ram
3813
material for partition
Last answer on 8/10/2012 5:29:01 PM. by tjackson. Forum started by archi verma
2268
make the best use of aluminium partition
Last answer on 3/28/2012 5:11:30 PM. by Swati Satija. Forum started by sankari
6656
How to Build Septic Tank for house
Last answer on 9/20/2012 5:51:39 PM. by PR Jawahar. Forum started by P. Panchal
2955
Last answer on 8/1/2012 9:53:21 AM. by Ravi. Forum started by J J Gupta
3505
Last answer on 11/8/2021 10:59:52 AM. by nehamehta. Forum started by J J Gupta
3031
Last answer on 4/1/2013 3:23:48 PM. by akmurty1. Forum started by kjeevanrao
2099
what is the correct sitting position for the reception in office
Last answer on 8/9/2013 11:17:44 AM. by S L Gupta (Civil Engg). Forum started by yogesh laxman nalawade
1852
Last answer on 8/9/2013 11:20:50 AM. by S L Gupta (Civil Engg). Forum started by yogesh laxman nalawade
5811
3792
9885
2670
4628
4143
2865
5006
3656
1865
2800
2610
2373
2462
2638
1807
3608
6254
Glass
Glass Partitions
Do you want natural light in your room or your house is small or you have an open floor plan. You may use glass room d..
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
