Tue Feb 18, 2014
jagminder
Topic: precast concrete wall or brick wall
which wall is good for building house precast concrete wall or brick wall....what is appox price difference....
Wed Feb 19, 2014
Dear Jagminder
Brick wall is better in the house than RCC wall, in RCC wall face difficulty in finishing, in electrical and water supply fittings.
Rcc wall is much costlier than brick wall for same thickness it is 3.5 time costlier.
Wed Feb 19, 2014
manish
Post subject: rcc wall
Dear Gupta ji,
I wish to construct a rain water harvesting underground tank. The size would be approx 10'*5'*5'. What would be better- solid rcc wall or brick wall. The cost of brick is around 7/- per pc. In rcc I will not need plastering and tiling. Kindly advice on the cost part in both cases. Thanks in advance.
Thu Feb 20, 2014
Dear Manish
For under ground tank construct RCC wall with plaster finish inside to avoid any leakage for safety of foundation of structure.
Sat Feb 22, 2014
Post #4
manish
Post subject: specification
Thank you Gupta ji.
Can you also guide me as to what should be the thickness of the Rcc walls and which mm sariya should I use. The tank will be around 8feet away from the super structure and will be under the driveway. Thanks
Mon Feb 24, 2014
Post #5
Dear Manish
Take the thickness of RCC wall at least 4'' and MS steel bars 10 mm dia @ 6'' center.
Tue Feb 25, 2014
Post #6
manish
Post subject: thanks
Thank you Gupta ji.You are a great help.
3470
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
9196
Vinod
2581
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by
nell
2697
Last answer on 2/20/2014 11:14:47 AM. by
HM12345
2992
1341
Last answer on 1/16/2017 3:05:19 PM. by
2523
1815
Last answer on 10/3/2016 1:56:08 PM. by
ajit kumar
2876
Last answer on 8/16/2013 9:44:01 PM. by
Rudra Nevatia
feroz khan patthan
2025
1859
Last answer on 8/22/2015 7:13:59 PM. by
bala
4057
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
4040
Cost Comparison Between Brick Wall & Concrete Frame Structure
Last answer on 7/3/2020 11:40:50 PM. by
PR Jawahar
PR Jawahar
1502
Last answer on 10/29/2016 2:54:11 PM. by
Er.S.K.Jain
1846
Last answer on 11/3/2016 2:26:29 PM. by
1989
Last answer on 6/1/2015 1:05:53 PM. by
Mohd
895
My home is 3 floor, ground Plus 2 floor. But built up with 4" brick walls along
Last answer on 7/3/2020 9:43:54 PM. Forum started by
Rohit Kumar
1797
Canvas Wall Art
Wall Decor
Cement Concrete
Concrete Mix Ratio
