Home -> Forums -> Construction -> Layout and House Plans -> prefabricated house versus brick and mortar
Sat Nov 30, 2013Total posts : 1
neelam rathi
neelam rathi
Topic: prefabricated house versus brick and mortar
intend to get a residential house contructed.which is a better option? A prefabricated house or a normal brick and mortar house with RCC beam?
Sun Dec 01, 2013Post  #1
Post subject: prefabricated house versus brick and mortar
Hello.. Neelam, If you have your own plot and intend to get a residential house constructed, first get a good planning of house according to your requirements.construction with RCC Columns and Beams and infill brick work is better option than prefabricated one. regards...
3651
3206
Nubian Vaults
Last answer on 12/31/2020 1:57:43 AM. by H S Rathi. Forum started by Boovarahan S
1666
Last answer on 7/3/2020 11:11:05 PM. by Navneet Jharia. Forum started by Sandeep
2587
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by S L Gupta (Civil Engg). Forum started by ahsan
1894
2991
2873
FLYASH OR CLAY BRICK
1483
ABOUT ROD AND MORTAR USED IN THE ROOFING OF THE HOUSE
Last answer on 10/12/2015 10:20:41 AM. by S L Gupta (Civil Engg). Forum started by sumit
2029
Need to strengthen brick wall and brick pillar house
Last answer on 5/3/2016 12:24:38 AM. by JAI PRAKASH. Forum started by Sudipto Choudhury
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by Kranap. Forum started by mamta
1958
2553
Mortar Plastering
Last answer on 10/11/2011 6:37:02 AM. by S L Gupta (Civil Engg). Forum started by sunny420
5943
Difference between Mortar and Masonary Plastering
Last answer on 10/11/2011 6:39:09 AM. by S L Gupta (Civil Engg). Forum started by sunny420
2840
Water seepage from RCC slab
3589
Per Sq:ft rate for flooring
2421
2017
2865
Bricks
3992
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2242
3595
2324
2090
2792
1548
2114
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
