| Plastering Plastering not only makes the surfaces smooth but creates a good finishing to the walls, ceiling and roofs also. |
| Canvas Wall Art Your home definitely reveals you. It reflects your interest and your sense of colors. A splash of innovations and colo.. |
Cracks at the junctions of Brick Walls and RCC slabs Handle the cracks in the walls initially because they can destroy smooth finishing of the plaster. |
What is the recommended thickness of POP on wall? In case of single coat plaster, the common thickness is 12 and 15mm.
| Basement Walls Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for.. |
| Specification of 'Bricks Walls' Strong brick walls are a symbol of strong building. Whole construction process somewhere depends on it. So here is a b.. |
| Wall Decor When it comes to wall decoration, it is difficult to choose accessories, materials, finishes, colors and patterns for .. |
| Checklist for Painting Work Before you start paint work, make sure that the surface is clean of dust, grease and other foreign matter. Decide on s.. |
Achieve a good quality in ‘Plastering’ Unique 'Plastering' makes a difference and requires a lot of skills which are discussed here.
