Layout and House Plans
The prevailing labor wages for construction of RCC building in Vijayawada is 150
Tue Dec 23, 2014
Vijay
Topic: The prevailing labor wages for construction of RCC building in Vijayawada is 150
The prevailing labor wages for construction of RCC building in Vijayawada is 150 to 180 per Sq.Ft. This is for any apartment that will have inner walls, plastering, closets, shelfs, etc etc. What should be the labour cost for RCC building per Sq.Ft if I want to have just slab and outer walls? I want to construct a building of 3000 Sq.Ft plinth area with just outer walls, windows and rolling shutters. What should be the labour cost per Sq.Ft for this kind of construction. Please help for this question...
The comment above talks about the image below.
Click on
the image to enlarge.
Tue Dec 23, 2014
Dear Vijay
It is better if you do the work with your own labor by giving some time for supervision. As for labor rate the contractor can claim extra but not give benefit for less work. For this contact 4 to 5 contractor of the area and give work to lowest bidder.
Fri Jan 16, 2015
They measure only the Lantel area, It doesn't matter whether you have walls or not.
2656
New Construction
Last answer on 8/6/2020 5:50:51 AM. by
VIPIN KUAMR
1424
Hello, My plot dimensions are 36*36 west facing, already roof completed, i want
Last answer on 8/31/2016 10:47:13 AM. by
krishna
2638
Last answer on 4/5/2012 6:36:29 PM. by
Jajati Pattanayak
4234
labour rate
Last answer on 10/27/2015 10:43:11 PM. by
Rahul
1314
Economical and reliable choice of type of exterior staircase to the rented 1st floor of house.
Last answer on 12/26/2016 1:12:50 PM. by
2559
Last answer on 10/15/2017 1:22:37 AM. by
gautam kumar
gautam kumar
62
Top Islamic Astrologers in Vijayawada 91-7681982445
Last answer on 7/5/2024 1:57:00 AM. Forum started by
Miyan Akram JI
54
Last answer on 7/5/2024 1:57:01 AM. Forum started by
Miyan Akram JI
59
Last answer on 7/5/2024 1:57:02 AM. Forum started by
Miyan Akram JI
53
Miyan Akram JI
59
Last answer on 7/5/2024 1:57:03 AM. Forum started by
Miyan Akram JI
56
Last answer on 7/5/2024 1:57:04 AM. Forum started by
Miyan Akram JI
3926
Kitchen Cabinets
Last answer on 7/3/2020 9:37:52 PM. by
madhuri
2821
building a house
nashir
3575
construction current rate
Last answer on 7/3/2020 11:16:44 PM. by
bharat patel
2523
Industrial RCC
Last answer on 5/28/2013 10:17:13 AM. by
shikha Chetal
4649
Last answer on 11/4/2021 8:45:13 PM. by
Prem Kant Mishra
Last answer on 6/7/2017 12:17:49 PM. by
Prem Kant Mishra
2977
Last answer on 7/3/2020 10:59:48 PM. by
satyawan
2691
Raj
2188
Amutha
2184
vanramr
2793
raghu
4520
Nitien Parmar
suryarao p
1890
santosh
2284
Deepak Giri
2267
ajay sharma
2767
u v sudhakar
3464
ramana
2356
srinivas kamsali
1968
tanaya483
2242
ramanapeddu
3595
SRIKANTH.S
2324
HIRA SINGH
2792
Alexander Graf
Mohiuddin
1548
uma shankar
2114
mohammedbasha
