Home -> Forums -> Construction -> Start Construction -> Which proporation of Concrete Mix is good; Volume or Weight
Thu Mar 17, 2016Total posts : 3
K M Sendhil
K M Sendhil
Topic: Which proporation of Concrete Mix is good; Volume or Weight
Dear Friends,
Kindly give your advices on Concrete Mixes which is good.
Whether it by Volume Basis or Weight Basis
Fri Mar 18, 2016Post  #1
Dear Sendhil
          The weight basis method of measuring the cement concrete mix is better.
Sat Mar 19, 2016Post  #2
K M Sendhil
K M Sendhil
Thanks, Sir.
Tue May 03, 2016Post  #3
Weight.
1777
1469
3804
concrete mix design software
3291
1460
Is the concrete mix ratio M20 (1:1.5:3) weight based? If yes, whether volume based 1:2:4 ratio is almost equal to M20?
Last answer on 3/10/2017 12:37:18 PM. by S L Gupta (Civil Engg). Forum started by vinu
1852
what is the density of alluminium per cum volume
Last answer on 10/6/2014 10:09:26 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
2891
Last answer on 5/25/2018 12:57:44 AM. Forum started by aniz
6495
1878
Roof Painting
2032
1722
CONCRETE MIX
Last answer on 7/3/2020 9:36:11 PM. by M Prabhu. Forum started by M Prabhu
2162
Ready Mix Concrete
Last answer on 7/4/2020 2:18:20 AM. by S L Gupta (Civil Engg). Forum started by Vishwanath
Ready Mix Concrete
4382
Ready Mix Concrete
2477
3478
Cost of concrete walls
3091
3393
1:2:4 mix or 1:3:3 mix
Last answer on 3/18/2014 1:08:38 PM. by S L Gupta (Civil Engg). Forum started by navneet
3467
2487
3313
3326
4456
4029
2254
2730
4239
5216
2399
2326
2027
2467
2147
3219
2078
12550
2197
2037
2759
Concrete Mix Ratio
Ready
Ready Mix Concrete
Tips for Cement Paint
CONCRETE
Concrete Decor
