Home -> Forums -> Construction -> Whitewash -> putty coating
putty coating
Wed Aug 06, 2014Total posts : 2
K Umapathi
K Umapathi
Topic: putty coating
Dear sur,
Is it necessary to apply a coat of white cement before applying putty? How many coats of putty is necessary?. Is it advisable to apply putty on external walls immediately finishing construction or after 6 months?. Some suggests that air crack appear on walls and hence postpone the putty coating and few suggests that air crack can be rectified by patch works. And also please confirm can emulsion paint be applied without putty coating? kindly advise me sir.
Thanking you.
With Regards,
K Umapathi.
Wed Aug 06, 2014Post  #1
Go for putty or white cement, any one of them, both are not required, putty is good. Yes outer walls has to be covered with putty asap.
Thu Feb 20, 2020Post  #2
          Thanks for visiting the site.
Whitewash-Construction Questions (19)
3283
Wall Putty on exterior wall
2991
Wall Putty ,primer and paint
3069
Painting
2929
Plaster
2145
acrylic vs primer
Last answer on 1/21/2015 11:35:40 AM. by S L Gupta (Civil Engg). Forum started by paresh
2084
CEMENT PANI - Plaster Works
8880
1896
wall putty
Last answer on 7/3/2020 11:12:22 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
4983
One putty mistry told that putty must be done before marble laying on floors as
Last answer on 7/4/2020 3:50:46 AM. by S L Gupta (Civil Engg). Forum started by Surinder Singh
2519
15489
apex ultima vs weather coat? please help me choosing the right exterior paint. a
Last answer on 12/6/2012 11:46:26 AM. by S L Gupta (Civil Engg). Forum started by rajarshi ray
4503
3084
4627
time for paint and wall putty
2212
Painting interior walls
536
2715
wall putty
Last answer on 1/2/2021 5:22:50 AM. by leelindsey. Forum started by paresh
9541
Wall Putty and primer
1706
Need help about painting and wall water proofing
Last answer on 3/11/2014 3:08:54 PM. by Ahmed. Forum started by vamsi
Which types of finishing/ protective coating materials are recommended for Aluminium doors?
Finishing/Protective materials for Aluminum Doors-Primer, Raw linseed oil, Turpentine, Exterior Grade enamel paint......
Tips for Oil Bound Distemper
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
Refinishing Hardwood Floors
Tips for Cement Paint
Textured
Textured Paint
Textured paint creates stunning effects on the walls of your house. It not only makes inspiring textures but also prov..
