quantity required for Tor steel Lintel
Sat Jun 30, 2012Total posts : 1
ndmalam
ndmalam
Topic: quantity required for Tor steel Lintel
i am building a home. covered area is 55x35 ft. Now i want to put rcc lintel . and want to know the quantity of cement. sand . bajri and tor steel. please help me. best regards
Fri Jul 06, 2012Post  #1
Post subject: Estimation can be done if the following info and...
For calculating the material and cost of the construction, GharExpert need following information and documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Exterior elevation design
7. Floor plans.
8. Structural drawings
12998
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by S L Gupta (Civil Engg). Forum started by sanjay
13756
2866
Steel calculation
722
5177
RCC Lintel , cast and material esitmate
Last answer on 7/3/2020 10:47:13 PM. by S L Gupta (Civil Engg). Forum started by ndmalam
3452
Steel in Lintel
Last answer on 8/26/2015 6:45:44 PM. by JAI PRAKASH. Forum started by krishna pratap
3207
steel
3495
2685
steel requirment
2083
help
Last answer on 1/9/2015 12:09:16 AM. by JAI PRAKASH. Forum started by Asif
1992
Residential complex
1641
Construction Cost for RCC Roof / SlabsI am constructing a house 25* 36. slab thi
Last answer on 11/6/2015 12:49:45 AM. by JAI PRAKASH. Forum started by sandeep
20126
3278
2999
2396
Last answer on 6/24/2013 9:59:46 PM. Forum started by chethan
2672
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
1878
PERFECT STEEL HEIGHT,WIDTH & NO OF QUANTITY
Last answer on 1/25/2016 2:31:29 PM. by DURJOU KUMAR MONDAL. Forum started by DURJOU KUMAR MONDAL
24
28
Types of arch
Type
HSD
Precautions
Steel
Steel Roofing
