Concrete Mix Ratio Compressive strength is the most important property of hardened concrete. It can be measured easily on standard sized .. |
| Designing a Foundation Foundation is the part of structure below plinth level and needs special care while designing. Whole design of the fou.. |
What is cement concrete and which are various ratios according to the site requirement? The cement concrete is a mixture of cement fine aggregate, coarse aggregate and water.
| Cement Concrete In the construction of building work, there is need of various types of building materials which are used during the c.. |
RCC Roofing This roofing is very versatile and provides great protection. |
| Rubber Roofing- Eco Friendly Option If you are looking for leak-proof roofing material, choose rubber roofing. Rubber roof is an eco-friendly, durable and.. |
