Tue Aug 11, 2009Total posts : 1
RG MAURYA
RG MAURYA
Topic: Which are recommended factors for the safety of building in earthquake prone areas?
i have brick masonary structure foundation with columns at all corners ...and foundattion is dug upto yellow soil...IS my house earthquake resistance
The comment above talks about the article   "Which are recommended factors for the safety of building in earthquake prone areas?"
Thu Aug 13, 2009Post  #1
S.Krishnan
S.Krishnan
Post subject: Safety of building in earth quake prone area
These are some factors recommended for safety of building in earthquake prone area.
  • R. C. C . band  with the size 75 mm to 100 mm thick  should be provided at plinth level lintel level and roof level.
  • Provide R.C.C. band in case of trusses or rafter to connect all the columns and walls for protection against earth quake.
  • Bricks should be first class bricks and having minimum crushing strength 105 Kg. per sq. cm.
  • Sand used for making cement mortar should be clean free from silt, vegetable matter, and other foreign matter.
  • The ratio of cement  sand mortar in brick work should be 1:4  but not less than 1:6 in any case.
  • The material used in cement concrete  should be according to the specification and the mix should be 1:5:3.
  • Mild steel used in R. C. C. work should be  tor  or ribbed and properly tested in the testing laboratory.
  • The cement used in construction work should befresh not effected by moisture and manufactured by reputed firm and not from local plant.
  • The bricks used in masonry should be properly soaked in water.
  • All construction work should be done by skilled mason, carpenter and blacksmith etc.
  • All the building members should be properly connected each others.
  • Proper curing should be done during construction work for obtaining maximum strength.
1106
Are TMT's building really earthquake resistant
Last answer on 8/20/2018 12:14:24 AM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
3437
Any interior decorators in Hyderabad quoting economical rates for quality service?
Last answer on 8/13/2015 11:52:23 PM. by JAI PRAKASH. Forum started by Murali
2840
Choosing the right type foundation and structure for house
Last answer on 9/30/2011 11:52:30 PM. by S L Gupta (Civil Engg). Forum started by Vinod
1363
How to design my house to be more flood and earthquake safe.
Last answer on 9/27/2018 1:25:04 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
1070
For porche area flooring, granite stone is slippery and kota stone prone to flak
Last answer on 7/4/2020 2:41:31 AM. Forum started by Surinder Singh
3247
Building a house in Kolkata Rajarhat area few initial questions
Last answer on 2/15/2013 12:40:16 PM. by DK. Forum started by DK
2007
3624
Wall unit
2101
1856
cost prize with fixing and locks and safety latch and eye view
Last answer on 6/21/2011 4:22:41 PM. Forum started by manmath
2130
Last answer on 1/16/2022 11:07:26 PM. Forum started by Aly Atif
1504
Discus on the relevance of best practice and code of practice on safety
Last answer on 3/28/2011 9:51:27 PM. by S L Gupta (Civil Engg). Forum started by onims
4891
Nice design for safety door.
Last answer on 1/22/2022 2:38:55 AM. Forum started by jyoti
1408
Dear sir , I am looking forward for a map of duplex / triplex of built up area
Last answer on 1/10/2016 8:55:35 PM. by JAI PRAKASH. Forum started by sunny
2497
Cost estimation for 3 stories apartment
Last answer on 11/23/2015 1:51:56 AM. by JAI PRAKASH. Forum started by Akshay
22186
Difference between plot size area, built-up area, plinth area
Last answer on 3/17/2016 12:21:27 PM. by S L Gupta (Civil Engg). Forum started by vamsi
3503
3057
Vastu home map east facing plot 25 * 28
Last answer on 10/8/2015 11:39:50 AM. by Amit Hasija. Forum started by sudipta sinha
24
28
What
What is recommended size and shape of building for the protection in earthquake prone areas?
All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s..
Earthquake
Finishing recommended for wood ceiling
There are many type of ceilings are provided such as stretch ceiling, wood plank ceiling, or steel ceiling. But do w..
Earthquake
Earthquake safety tips
Earthquake can strike suddenly with very little warning. One minute you may be enjoying the company of your kids and f..
What are various termite control methods?
INITIAL INSPECTION AND REPORT requires a complete thorough inspection of the buildings and surrounds, and a detailed w..
