redering required
redering required
Mon Jun 30, 2014
anand
Topic: redering required
i require rendering facility, can anyone do it for.
i will provide the 3dmodel in autocad
regards,
anand shah
9243249988
Mon Jun 30, 2014
vaibhav
Post subject: For 3D rendering
I can make 3D rendered view.in max vray with very good result.
1 image cost 5500rs.
Wed Jul 02, 2014
Will contact u ASAP. Tell me what can you offer per render?
Contact: 08802836186
Sat Jul 05, 2014
anand
jai prakash/vaibhav
can u show me the samples, which are rendered by you previously.
BIRDSVIEW.jpg Sat Jul 05, 2014,&n
Mon Jul 07, 2014
Post #4
Please check my profile pics
Sat Jul 12, 2014
Post #5
anand
Post subject: check attachment
enclosed in the attachment is the autocad file
nandishelevation3d1.zip Sat Jul 12, 2014,&n
Sat Jul 12, 2014
Post #6
anand
Post subject: how much will u charge for this attached auto ca...
how much will u charge for this attached auto cad file
2217
Last answer on 12/14/2010 7:35:48 PM. Forum started by
Rakshit
1944
Last answer on 11/25/2016 2:18:45 PM. by
Khalid Rashid
1606
How much Marole required
Last answer on 7/3/2020 11:26:58 PM. by
Yousuf
2022
required plan for 15/40 site 2bhk with vastu
Last answer on 1/23/2022 3:38:51 AM. by
mangala
30 X 50 EAST FACING REQUIRE PLAN WITHGROUND + 3 FLOORS
Last answer on 7/1/2016 12:51:14 PM. Forum started by
Dr.Vijayakumar gampa
2871
Steel calculation
Vamshidharreddy
2425
20*52 plot consruction house plan material estimite required
Last answer on 7/4/2020 2:11:15 AM. by
sanjay mishra
729
Last answer on 9/19/2020 12:24:32 AM. Forum started by
Rohit Kumar
2327
Last answer on 4/13/2011 6:59:26 AM. by
rammohandas
2064
how much green paint required in 1sqm
Last answer on 7/8/2011 8:24:30 AM. by
Abrar Ullah
sherab tenzin
2452
Last answer on 8/6/2011 2:32:51 PM. by
nita
3046
Last answer on 8/18/2011 6:51:51 PM. by
prasadtvp
chella earnest
3172
Last answer on 12/31/2020 2:11:59 AM. by
Ashok Negi
VILAYATWALA ALIASGAR ABBASI
2552
Tips for Varnish
Last answer on 3/17/2010 12:38:44 AM. by
vinay meghani
2818
Last answer on 12/31/2020 2:51:38 AM. by
SHAILESH
2012
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by
Krishna Equytech
2022
COST DETAIL REQUIRED
Last answer on 12/24/2013 11:43:24 AM. by
ANNA.B
2278
swarup chakraborty
2403
ineed plan and elevation and 3ddrawings.how much required
Last answer on 4/4/2014 2:07:38 PM. by
subramanian
2480
