Home -> Forums -> Construction -> Fine Sand -> robo sand vs natural sand
Sun Apr 06, 2014Total posts : 6
shaik khaja nayab rasool
Topic: robo sand vs natural sand
hai..sir which fine aggregate is good for slab purpose(M20) is it robo sand (stone dust)  or natural sand(river sand).recently in our construction we use robo sand but it gives crack on slab if we robo sand how we avoid the crackes
Mon Apr 07, 2014Post  #1
Dear Rasool
The sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
The quality of the sand has more impact on the strength of the structure in spite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength.
WASH the sand before use so that silt contents should be reduced, the problem of cracks is mainly due to silt contents.
    See the Article below
http://www.gharexpert.com/articles/Fine-Aggregate-1475/Specification-Fine-Aggregate-Coarse-Sand_0.aspx
http://www.gharexpert.com/articles/Cracks-718/Which-Various-Reasons-Cracks-in-Buildings-_0.aspx
Tue Apr 08, 2014Post  #2
Post subject: test for slit
thank u sir for ur respond ...what is exact and simple test for calculating the slit content in robo sand in the field..
Tue Apr 08, 2014Post  #3
thank u sir for ur respond ...what is the exact and simple method for calculating the slit content in robo sand in the field..
Wed Apr 09, 2014Post  #4
Dear Rasool
             The silt contents exactly calculated in lab with the help of measuring cylinder.How ever you can see the silt contents in glass pot. Put some quantity of sand in the glass and add water to a higher level than sand. Now stir the mixture of sand and water and after stiring or shaken  it will be left to settle. After some time you will see the layer of silt on the top of the sand which will give you the  silt contents quantity.
Wed Apr 09, 2014Post  #5
I guess. if "Robo Sand" (crusher dust) is made of stone particle, then it must be equally strong. I have no proof, and I have never used robo sand but I think It can be used in place of river sand.
Mon May 19, 2014Post  #6
       The sand for concrete/ flooring should have fine ness modulus not less than 2.4 and silt contents should be less than 4%.
Fine Sand-Construction Questions (27)
1762
1457
3712
2101
river sand
3009
M-Sand for Plastering
3493
Robo Sand for Brickwork
2011
coarse aggregate
2327
Sand units
1706
Sand units
1525
Sand units
13271
What is the advantage and disadvantage of using Robo Sand (stone crush) in RCC a
Last answer on 10/17/2014 9:27:21 AM. by SANJAY DUSANE. Forum started by Ajith Prakash
6450
3148
Last answer on 7/3/2020 9:54:13 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2242
sand alternate for concrete
1697
I like this picture plese sand me plan
Last answer on 8/4/2014 11:18:58 AM. by seema tyagi. Forum started by sandy
3791
1781
what is sand blasting in fabrication work
Last answer on 10/4/2014 12:33:58 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1533
can sand blasting is possible at site
Last answer on 10/5/2014 11:38:19 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
2192
2327
Sand units
1706
Sand units
1525
Sand units
3009
2035
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
2809
sand wight per cu.feet
Last answer on 11/5/2012 11:47:35 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3525
alternative for river sand
Last answer on 6/11/2011 9:17:04 AM. by S L Gupta (Civil Engg). Forum started by sudakar
Skylight
Skylight Ventilation
Skylights introduce healthy atmosphere and can save large amounts of energy in homes. They create energetic feel and p..
Swimming
Swimming Pool Filters
