Home -> Forums -> Construction -> Cement Concrete -> roof concrete
roof concrete
Thu May 22, 2014Total posts : 2
sakthi
sakthi
Topic: roof concrete
what ratio for roof concrete in residencial building?
Thu May 22, 2014Post  #1
Post subject: Please check
http://www.gharexpert.com/Interior_decorating_pages/roof_concrete_ratio_1_2_4.aspx
Thu May 22, 2014Post  #2
Dear Sakthi
            As sh Jai Prakash said the ratio of cement concrete in construction of  roof should be 1:2:4.  but now taking safety against Earth Quack the ratio of cement concrete in roof construction should be 1:1.5:3.
2413
2027
3272
Roof Concrete Strength
6597
Reply to Roof Concrete Strength
Last answer on 2/19/2022 2:39:24 AM. by Zainab Pollard. Forum started by Jahankumar
11246
CURING ON ROOF CONCRETE
Last answer on 3/19/2014 10:26:34 AM. by Ahmed. Forum started by K Umapathi
2063
Minor crack in the roof concrete
Last answer on 9/22/2015 12:41:33 AM. by JAI PRAKASH. Forum started by bala
1774
Extending the Roof concrete
Last answer on 11/1/2015 7:02:15 PM. by JAI PRAKASH. Forum started by Balan
1523
Water leakage from roof concrete
Last answer on 7/3/2020 11:14:37 PM. by S L Gupta (Civil Engg). Forum started by Aravind Rahul
2107
2948
Lightweight Concrete Roofing
Last answer on 10/31/2012 12:32:07 PM. by S L Gupta (Civil Engg). Forum started by Ted Junior
1067
1699
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
3142
sloping roof
2212
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
9196
5486
Roof Slap & Roof Beam
Last answer on 7/4/2020 2:23:44 AM. by S L Gupta (Civil Engg). Forum started by Jahankumar
2802
precautions to avoid water seepage through concrete roof
Last answer on 4/12/2014 12:54:34 PM. by viju. Forum started by viju
3470
Cost of concrete walls
1794
STP
3108
3652
4349
rate comparison
3205
Concrete Mixture
3142
sloping roof
2090
15807
6471
2380
leakage in new slab
1528
Guide me
5119
2536
Civil Eng Stair Design
2536
Related to Sunken Slab
1859
1998
Concrete Hollow Block Masonry
3200
Ready Mix Concrete
Cooper
Concrete Decor
