Home -> Forums -> Construction -> Rainy Water Drainage -> roof leakage during heavy rains in bangalore
Fri Nov 27, 2015Total posts : 3
manjuks
manjuks
Topic: roof leakage during heavy rains in bangalore
We have a room constructed on III Floor - above this we positioned 3 water storage tanks- water seepage was there during heavy rains.The platform above roof to support water tanks was removed and re laid once again.But  on recent rains we have seen again  water seepage below the paltform at corner.
How to prevent the water seepage ? Is the  water seeping thro cracks developed there ? It is observed that during continuos rains only water seepage is there.
Any  solution to solve this problem ?
k s manjunatha
m 9986442930
Mon Nov 30, 2015Post  #1
Dear Manjuks
         From your question it is observed that leakage is during continuous rain.  I am in view that there is slope problem. The water stand on the area due to not having proper slope and take time in clearing the water from roof either due to having not proper slope or not having proper diameter of  rain water pipe which take time to clear the rain water.
 There is possibility of having crack on the joint of platform of water storage with roof, which should be checked and repaired.
You should take help of any good  engineer or mason who will give solution after site visit.
Tue Dec 01, 2015Post  #2
Can you show photos of  roof top. where tanks are placed.
I think your roof has got settled because of heavy load of tanks. you can solve it by making new base for tanks. make it 2 feet above the roof.
share some pictures so that I can better solution.
Wed Dec 02, 2015Post  #3
Share the pics.
Rainy Water Drainage-Construction Questions (22)
2748
roof leakage
2901
RCC ROOF LEAKAGE
Last answer on 12/5/2012 1:40:32 PM. by S L Gupta (Civil Engg). Forum started by sivarajen
2177
I want to cover my terrace because of leakage problem during rains.If i want to
Last answer on 9/12/2014 9:53:08 PM. by JAI PRAKASH. Forum started by Akshata Rao
1897
3967
Roof leakage
5662
2138
1822
1781
2973
Nubian vault and rains
Last answer on 12/31/2020 1:57:20 AM. by H S Rathi. Forum started by Boovarahan S
3153
APP membrane
2043
Leaks in roof
Last answer on 6/20/2016 2:44:10 PM. by lalit. Forum started by Ram
1635
Leaks in roof
Last answer on 7/4/2020 12:15:12 AM. by JAI PRAKASH. Forum started by Ram
3123
2613
Starting Construction during rains
Last answer on 12/31/2020 2:00:39 AM. by H S Rathi. Forum started by Jyosna
2684
Impact of Starting construction during rains
Last answer on 12/31/2020 2:00:26 AM. by H S Rathi. Forum started by Jyosna
2135
RCC SLAB
Last answer on 8/10/2020 11:19:07 PM. by S L Gupta (Civil Engg). Forum started by nagendrabk
1731
1959
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
2581
Rain Water Harvesting
Last answer on 2/7/2022 9:00:21 AM. Forum started by naveenti@gmmail.co
1876
Last answer on 11/29/2021 2:50:23 AM. Forum started by George Mercier
2615
How to hide Rain water pipe
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
Rain
Cooper
Electric
