The roof slab is layed with clean shuttering plates and some places probably due
Tue Apr 02, 2019Total posts : 2
Surinder Singh
Surinder Singh
Topic: The roof slab is layed with clean shuttering plates and some places probably due
The roof slab is layed with clean shuttering plates and some places probably due to collar plate the separation line is 3-5mm updown. No plaster or POP is done. Putty is to be used directly over ceiling surface as it came off the plates after grinding with sand paper to clean neru or pure cement layer to increase adhesion. Some putty workers are suggesting to mix POP with putty and fill these to even surface and others are saying use putty only. There is also a product birla levelplast for thicker filling. What is its composition? What is best way to fill 5mm depressions.
Wed Apr 03, 2019Post  #1
           There are so many method to level the surface as described by you. All are effective for 5mm thick depression.
       If you are more particular than mark the depression portion first than roughened the depressed portion by chiseling after that cure the portion for 24 hours than apply the cement shullery with painting brush than apply thin required coat of cement mortar 1;4 and after setting it cure it for 3 days. After it you will do any finishing on the surface which will be as good as you want.
Fri Apr 05, 2019Post  #2
Surinder Singh
Surinder Singh
Post subject: Thank you for reply.
Thanks for the reply.
2352
laying of roof
25607
CURING TIME FOR RCC ROOF
3087
2248
2126
6694
2936
Right price or not .. Kindly advise
Last answer on 7/3/2020 9:28:23 PM. by S L Gupta (Civil Engg). Forum started by everfor
9893
191900
3603
What is the cheapest form of waterporoofing the terrace?
Last answer on 7/21/2012 3:35:37 PM. by S L Gupta (Civil Engg). Forum started by Vipul Hasija
1908
2090
2527
RCC Slab -Curing
3980
Roof leakage
4836
2125
CRACK IN CENTRE OF SLAB
1885
Last answer on 4/12/2015 5:58:38 PM. by D.C.tandon. Forum started by SREENIVAS K
2089
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by Girish. Forum started by Girish
Centering
Bathroom Cleaning Tips
Carpet
Carpet Cleaning Tips
Kitchen Cleaning Tips
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
