roof thickness
Mon Jun 05, 2017Total posts : 1
gautam kumar
gautam kumar
Topic: roof thickness
sir can you tell what is the minimum  and maximum thickness of a roof?
Tue Jun 06, 2017Post  #1
        The thickness of roof/ slab is laid according to loading condition and this is calculated by structural engineer on the bases of span of the slab and load bear by the slab i.e live load and dead load.
However in general case the thickness of slab of simple room is 4.5'' and maximum for house may be 6''.
Roof Beam
5196
24720
3591
18416
3966
Roof leakage
2978
1766
2752
Last answer on 8/26/2013 1:23:28 PM. by S L Gupta (Civil Engg). Forum started by ragha
11037
2446
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
1777
Hollow Brick Wall thickness for RCC roof
Last answer on 8/10/2015 10:12:46 AM. Forum started by gpeter
42571
Labour Cost for Roof RCC work
8278
2699
2847
Steel calculation
2782
7207
2108
Floor thickness
263
78
27
24
29
29
28
26
26
27
23
23
20
29
20
29
26
22
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
