roofing
Mon Oct 12, 2015Total posts : 2
sumit
sumit
Topic: roofing
Q-1 I MEANT TO SAY THE TYPES OF ROD THAT CAN BE USED IN ROOFING { like THERE 8 mm ROD , 12 mm ROD and 16 mm ROD}.
Q-2 BUILD UP AREA IS 37 x 21 feet and THERE ARE  12 BEAMS.NOW HOW MUCH ROD THAT CAN BE USED FOR and SPECIFY THAT HOW MUCH ROD OF :
  • 1> 8 mm  -
  •  2> 12 mm -
  • 3> 16 mm -
is required for roofing.
Tue Oct 13, 2015Post  #1
      Use 12mm dia MS Steel bars as main bar in slab and 10 mm bars on other side. In beam use 16 mm dia bars and 8 mm rings.
Wed Oct 14, 2015Post  #2
Use 16 mm for beam only. Use jaal of 10-12mm for middle pertion.
Questions (40)
8421
Roof Beam crack
2850
2371
Roof construction
2158
1837
1792
3980
Roof leakage
1648
2054
4647
12252
2353
laying of roof
3272
Roof Concrete Strength
1875
2609
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
1556
Last answer on 6/7/2017 12:20:58 PM. by S L Gupta (Civil Engg). Forum started by Sandeep Vidwans
1304
2107
1280
if the room top not toching the roof then it is considered as room
Last answer on 10/30/2017 11:59:46 PM. by S L Gupta (Civil Engg). Forum started by div
15
17
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
