Home -> Forums -> Construction -> Cement Concrete -> What is the rough Cost of conncrete (1:2:4) per cubic meter?
Mon Apr 02, 2012Total posts : 3
Razi
Razi
Topic: What is the rough Cost of conncrete (1:2:4) per cubic meter?
Can any tell me the rough cost of conncrete (1:2:4) per cubic meter?
Tue Apr 03, 2012Post  #1
Dear Razvi
            The cost of cement concrete 1;2;4 is depend on the cost of the material in a particular area where work to be carried out and labour is depend on the in what component it is to be laid i.e. slab, facia, road pavement etc. The general rate is Rs110-00 per cft. For more detail about construction visit gharexpert.com website.
Tue Apr 03, 2012Post  #2
Razi
Razi
Post subject: Thanks
I got the rough idea atleast. Concrete work is for school building to be built in Purnea, Bihar.
Thu Oct 16, 2014Post  #3
In fact the rate varies  depending on area, labour and material cost .but in genral rate of (1:2:4)  M-15 Grade concrete is  rs: 5000 per cum
13716
rcc rate per cubic meter
Last answer on 10/20/2014 12:03:29 PM. by S L Gupta (Civil Engg). Forum started by anks
2163
Simple way for explain Cubic meter
Last answer on 2/18/2011 11:29:37 PM. Forum started by KS T9
2011
2845
1627
Road Construction
Last answer on 9/13/2016 3:04:32 PM. by S L Gupta (Civil Engg). Forum started by Bharat Kumar
6222
1955
Transport
Last answer on 4/2/2016 12:12:42 PM. by S L Gupta (Civil Engg). Forum started by Bunkera1993
16790
Construction Cost per square ft in Gurgaon
Last answer on 2/22/2013 11:53:26 AM. by S L Gupta (Civil Engg). Forum started by Pawan Rao
4012
what is the weight of MSA 45x45x6 angle per meter?
Last answer on 12/31/2020 2:08:28 AM. by Priti Arora. Forum started by K.SRINIVASAN
5312
Setback or bylaws as per BDA
Last answer on 1/13/2011 7:17:31 PM. Forum started by ranjeeth
2721
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
2651
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
1765
Last answer on 8/8/2016 2:46:05 PM. by S L Gupta (Civil Engg). Forum started by arvindkori
2086
Types of Windows and Door options in uPVC
Last answer on 5/25/2015 12:51:15 PM. by JAI PRAKASH. Forum started by harsha gv
2658
2861
3275
what is the cost of rolling shutter per sft what guage should br used
Last answer on 8/27/2013 9:57:24 PM. by kiran kumar 3k. Forum started by kiran kumar 3k
4045
2157
3461
Cost of concrete walls
1767
STP
3096
4334
rate comparison
3186
Concrete Mixture
3125
sloping roof
2075
15628
6433
2352
leakage in new slab
1510
Guide me
4993
2512
Civil Eng Stair Design
2512
2319
Related to Sunken Slab
1844
1988
Concrete Hollow Block Masonry
2398
roof concrete
3190
Ready Mix Concrete
Arcade (Architecture)
what is an arcade? Read the article to know more about it.
Brick Arches
Results of 'Design A Dream Home' Competition
The results are following.
Importance
