Home -> Forums -> Construction -> Fine Sand -> sand wight per cu.feet
Mon Nov 05, 2012Total posts : 1
aammiitt
aammiitt
Topic: sand wight per cu.feet
how much sand(yamuna, himachal) weight is there per cu.feet? the sand is for plaster. it is generally wet with little mixture of bazri in it.
they are charging me rs.30/- per cu.feet and rs.75 per quintal. what should i take it in.....per cu.feet or per quintal?
amit
Mon Nov 05, 2012Post  #1
Dear Aammittii
    The weight of sand is 36 to 40 kg per cft.
Fine Sand-Construction Questions (27)
45464
how much cu.m of earth can excavated by machine per day
Last answer on 4/3/2021 12:46:18 AM. by prasadtvp. Forum started by sherab tenzin
3112
estimation
Last answer on 7/3/2020 10:38:18 PM. by jayaraaj. Forum started by j.maheswari
2521
construction const
13755
2102
Types of Windows and Door options in uPVC
Last answer on 5/25/2015 12:51:15 PM. by JAI PRAKASH. Forum started by harsha gv
2633
tiles
2731
present cost of constuction per sq feet
Last answer on 11/29/2011 3:40:09 PM. by S L Gupta (Civil Engg). Forum started by ajeett
2662
I want to know the cost of this flooring per square feet
Last answer on 8/27/2013 12:29:33 PM. by S L Gupta (Civil Engg). Forum started by b.jaganathan
3457
I want do construct a home, plot size (20x50)feet.What is the construction cost
Last answer on 3/25/2016 3:05:19 PM. by S L Gupta (Civil Engg). Forum started by Santosh Singh Bhadoria
2072
Last answer on 1/8/2018 11:06:10 PM. by S L Gupta (Civil Engg). Forum started by ravikumar
2260
m15 cost vs m20 cost
2012
coarse aggregate
3713
1766
1460
2327
Sand units
1706
Sand units
1525
Sand units
2746
2193
2327
Sand units
1706
Sand units
1525
Sand units
3009
M-Sand for Plastering
16073
robo sand vs natural sand
2035
Alternate for River Sand
Last answer on 2/25/2013 2:02:46 PM. by RENJI. Forum started by RENJI
3526
alternative for river sand
Last answer on 6/11/2011 9:17:04 AM. by S L Gupta (Civil Engg). Forum started by sudakar
What is acre
Designing
Designing a Foundation
Through
