Home -> Forums -> Construction -> Brick work -> send orientation for 1200 sq feet construction on 1600 sq feet plot
Sat Apr 19, 2014Total posts : 1
atulbelokar
atulbelokar
Topic: send orientation for 1200 sq feet construction on 1600 sq feet plot
Mon Apr 21, 2014Post  #1
Dear Sir
      There are some residential plan on the website gharexpert.com where rates are given on the plan. If you want drawing of any residential or commercial building than send your requirements to suppotr@gharexpert.com there expert team will decide about cost.
2991
Pls send me construction plan to 30x60 sq feet plot
Last answer on 11/3/2016 11:02:48 AM. Forum started by Kiran Surve
4757
i want a home plan facing northwest.size 1200 sq.feet
Last answer on 10/19/2010 2:08:24 PM. by ashokkumar. Forum started by gragory
3635
2126
construct of new house
Last answer on 12/24/2015 4:15:00 AM. by JAI PRAKASH. Forum started by renu
5834
Last answer on 7/3/2020 9:39:24 PM. by ramu771964. Forum started by RAKESH DIXIT
2420
hallo sirmy plot size is 118*34 sq my plot face is north ,north to south 118 sq
Last answer on 7/2/2020 10:07:48 PM. by Gunjan Utraja. Forum started by manoj
3925
2439
False Ceiling
Last answer on 9/1/2015 2:55:46 AM. by JAI PRAKASH. Forum started by Vijay
1671
How many sq feet marble needed in 1700 sq feet area with kitchen and two floor stairs.
Last answer on 7/12/2016 10:45:15 AM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
1601
Last answer on 10/18/2016 5:17:56 PM. by S L Gupta (Civil Engg). Forum started by Dheeraj Grover
2552
HOUSE MAP
Last answer on 7/2/2019 11:44:00 PM. by S L Gupta (Civil Engg). Forum started by mohit pal
1394
about construction
Last answer on 1/15/2015 10:40:16 PM. by JAI PRAKASH. Forum started by MANISHA
2682
i have 600 sq ft plot at nandhi layout bangalore opp to devi temple , between pl
Last answer on 7/30/2014 10:56:32 AM. by S L Gupta (Civil Engg). Forum started by balakrishna
1871
I have 10 feet width and 84 feet depth plot, how I construction students lodge
Last answer on 10/4/2015 12:49:06 AM. by JAI PRAKASH. Forum started by chandan
3542
Contruction Tool
2747
2972
duration of constucting home
4372
Last answer on 4/25/2014 2:55:51 PM. by seema tyagi. Forum started by PANKAJ
3669
wals
3264
compound wall
21879
3280
Bedroom Wardrobes information
2246
2206
1495
1965
1732
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
What is acre
Orientation
Orientation of Building
Designing
Designing a Foundation
