Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> sewage pipes
sewage pipes
Sun Jan 05, 2014Total posts : 4
rajesh
rajesh
Topic: sewage pipes
Dear sir, I require PVC 4 inch pipes for sewage, lots of brand in market,first I like to know what is differance between 4kg pressure pipe and 6kg pressure pipe, second what specification I shall look while purchasing pipes.My second question is for hot water supply CPVC pipes are good or G.I.Pipes. Thanks and hope again an early reply. - Rajesh Aggarwal.
Mon Jan 06, 2014Post  #1
Dear Rajesh
         Use ISI or first quality PVC pipe, 6kg pressure pipe is better than 4 kg pressure pipe.
For using hot water for bath or kitchen than use UPVC OR GI pipe if you require long time supply for hot water than use G I Pipe.
Mon Jan 06, 2014Post  #2
rajesh
rajesh
Thanks, Mr. Gupta, Is UPVC pipes good for  hot water as per my reading CPVC or G.I.   pipes are good for hot water.please clarify. Thanks.
Mon Jan 06, 2014Post  #3
Dear Rajesh
     Take the product literature of both UPVC AND CPVC than decide about use or use GI PIPE.
Wed Jan 08, 2014Post  #4
Ahmed
Ahmed
Hi Rajesh
My exp is to use CPVC which most builders do or GI but not UPVC.
71
Need Help
Last answer on 1/28/2011 10:06:57 AM. by Nikita. Forum started by abid_baig@yahoo.com
1457
dear sir, I have lot measuring 25x25 Sq foot on 20 feet road.I want to construct
Last answer on 1/10/2016 8:59:17 PM. by JAI PRAKASH. Forum started by sunny
1646
duplex / Triplex plan of the built up area 20x20 Sq foot
Last answer on 1/10/2016 8:55:51 PM. by JAI PRAKASH. Forum started by sunny
2386
Sewage and drainage lines
1989
PLUMBING
2931
9175
2177
can waste pipe pass the inner maingate ?
Last answer on 12/31/2020 2:33:37 AM. by S L Gupta (Civil Engg). Forum started by ankit gupta
3268
4076
drainage pipe line for toiletfor south facing house
Last answer on 1/19/2022 6:35:06 AM. by S L Gupta (Civil Engg). Forum started by ajitkumar
2342
what is the diffrence between u-pvc ans pvc pipes
Last answer on 7/31/2014 7:59:31 PM. by GUNA. Forum started by SANJAY DUSANE
1618
1498
Last answer on 1/17/2015 11:33:39 PM. by JAI PRAKASH. Forum started by mohit kumar
2625
How to hide Rain water pipe
3805
cpvc pipes v,s gi pipes
1960
how to do gas piping for a residential ground floor independent building should
Last answer on 12/26/2011 7:59:32 PM. by S L Gupta (Civil Engg). Forum started by elizabeth
2943
SIR, I AM CONSRUTING MY HOUSE IN PATIALA AND CONFUSE THAT WHICH PIPE GI , PVC ,U
Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI
2143
how do you stop dampness in old buildings especially if it is due to burst conce
Last answer on 11/13/2010 8:21:32 PM. by S L Gupta (Civil Engg). Forum started by sangameshs
2213
Do you have paint reps in the USAaround the northwest Indiana area.I have a cust
Last answer on 11/16/2012 8:35:46 PM. Forum started by Jackie Martin
1885
tap Connection
3628
sunken slab
2508
How to hire a plumber
3498
1675
2321
3860
flush toilet
1960
4721
Cost estimation for sump tank
2219
water supply
2042
Underground Water storage
2251
commode & flush type
1948
WC issue
5626
Over-Head water Tank
2337
Vastu for septic tank
2483
2474
Septic Tank Design
3387
3753
position of septic tank
Sewerage
Sewerage & Plumbing System
General
Various
Checklist for Plumbing
